05-04-2016, 06:36 PM
Stanwood
Installing Beltline Molding
I have a 2005 25"Safari with some filliform corrosion around the beltline, I thought if I could install beltline trip to cover the corrosion and maybe control it somewhat and cover it up. I found beltline extrusions at Airstream Supply, the molding comes in 16' lengths. My question is, has anyone had experience installing the beltline trim. Is it screwed or rivited on? Any special tricks in getting it installed so it looks good? Any help or information would be greatly appreciated. Thanks!
10-04-2016, 02:01 PM
Albuquerque
, New Mexico
Have the same question
We have a 19ft with the same issue. Have you found a way to,cover it up?
10-04-2016, 02:46 PM
2015 23' FB International
2007 19' International CCD
Steamboat Springs
I'm surprised there has been no response to this question.
There is a youtube video by Long Long Honeymoon titled "Repairing Chrome Trim on our Airstream Travel Trailer RV".
10-04-2016, 04:08 PM
1976 31' Sovereign
Oswego
On my 76 AS belt lines are riveted on, bottom one covers where banana wrap and side panels join together. As far as filliform no idea how to cover or cure. Older AS don't have this prob. Bill
10-04-2016, 09:18 PM
1976 25' Caravanner
Salt Lake City
, Utah
Beltline on my '76 is riveted on with pop (blind) rivets, again, where the shell meets the belly wrap. In fact, I'm installing it now after a shell-off re-do. I also bought some new beltline extrusion from Airstream Supply. Also the plastic insert that fits into the channel and covers the rivets. I suppose one could apply this beltline on a newer Airstream for the purposes stated by the OP. Good luck with that!
10-04-2016, 10:13 PM
2006 25' Safari
St. Augustine
Oh boy. Sorry I took so long to see your post. I have a 2006 Safari 25 and it had severe filiform at the belt line. I ordered the molding and put it on. I contacted Airstream when I got it to ask about what to use- rivets or screws and was told screws, that either would work. I used stainless screws. It was not difficult to put on. Once started I just kept working down the side and bent it as I moved around the trailer, pushing it against the side. My model, a Safari had a bit of a different rear area that I had to come up with a different design for. I added an end cap to each side instead of just wrapping around the back due to obstacles. I used a copper grinding wheel to remove the surface corrosion and then sealed the surface with three coats of sealant before attaching the moulding and then adding the silver insert trim. I also sealed the top of the moulding with that silver stuff Airstream uses for seams. There are no tricks that I know of but you can use the upper/lower seam and rivet line as a guide and drill between rivets every so often- that's what I did. It made the trailer look like new.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
10-05-2016, 09:06 AM
Stanwood
Beltlijne install
Thanks for the response, did you put the screws into the ribs or just into the aluminum skin? If you put it in the rib, I would think you would have to remove the rivet. They must have used a poor grade of aluminum on these trailers. I have removed the corrosion and covered it with a silver paint, but I thin the trim would cover that. Thanks again!
10-05-2016, 10:31 AM
Curly LaJolla
1977 Argosy 24
Beaverton
, Oregon
I'm going to drop this here for possible future user reference.
Our '77 Argosy has both belt line and bottom moldings. The aluminum extrusion is riveted to the side, of course. The vinyl insert has to be secured at each end because the stuff shrinks and grows with the ambient temperature. Quite frustrating until I realized my issue. My problem was a 24' trailer, that is eight feet wide, is longer around than the 50' rolls that I found at Out of Doors Mart. That's fine for the bottom, where the wheel lip moldings take up four or so feet per side, but the only real break in the belt line is the door. That means a split in there somewhere, with added vinyl molding being needed. I had a little left over that was usable, from what we had removed, and went in with that on the rear of the trailer. Based upon the temperature the joints are anywhere from tight to several inches apart, on each side. I'll fab some clips eventually and secure the molding. It'll look fine but a 60' roll should would have helped :-) Also, it's probably best to install the stuff when it's cold outside.
Curly LaJolla
1977 Argosy 24'
"What fun is it being cool if you can't wear a sombrero?"
10-05-2016, 11:13 AM
2005 25' International CCD
Westlake Village
Haven't done the work yet but will soon thus very interested in this post.
Also have a 2005 25ft SS CCD Unfortunately, same common issue and we have it bad with most filiform around the beltline. We can cover
90% of the ugly by also adding fresh beltline all around.
Saw how factory secured lower rub rail with a single smaller black coated rivet approx 12 inches alternating just above or below the existing rivets whenwe recently replaced the oxidizing lower rub rail flexible chrome insert. Assume the both rails would use same rivet and method although upper rail is narrower than the lower.
If you attack the project, would be nice to see before and after pics !
Relaxing is hard work.
Vantair
2005 25ft International CCD SS
2020 GMC Sierra Denali Diesel 2500 4X4 10 spd 3.43 Int sway/tow controller
1981 Honda Trail CT110 1X0..no sway control
10-05-2016, 07:18 PM
2006 25' Safari
St. Augustine
You do not have to remove any rivets. The beltline moulding goes over top of the rivet line. The screws are through the skin and sealed. Then I sealed the top of the moulding as well. This was one of my first projects in 2012 after I bought the trailer. I've had no issues. I cannot find a close up picture of the trim but I am posting one with the customized back and, if I can find it, one of the side from afar. I thought that following the design on my trailer, the trim would be right on top of the lower edge of the back window and I did not like that.
10-05-2016, 10:49 PM
Stanwood
Beltline molding
Thanks again, it looks great, I guess I better bite the bullet and do it!!! Will send photos when i finish, put the trailer yesterday, maybe the last time for this year.
10-06-2016, 08:10 AM
Albuquerque
, New Mexico
I found another method on airforums and going to give it a try. Take a look:
http://www.airforums.com/forums/f142...31743-165.html
Last post by sb55 (painting a stripe)
10-06-2016, 06:52 PM
2006 25' Safari
St. Augustine
er, uh, be careful. Painting aluminum silver is not easy and it, IMO, will not look the same. I have some spots on mine that I did. I bought four different silver paints before settling on one but even still, it is visibly different. IT DOES look BETTER than any larger filiform bubbles but I would leave little ones alone, personally.
10-07-2016, 05:59 AM
Albuquerque
, New Mexico
Thanks, I agree about the silver paint......scared to try it. The post was about adding a painted stripe over the corroded rivets. It looks great in the pics
10-07-2016, 06:05 AM
Albuquerque
, New Mexico
Do you have any suggestions on where to find airstream parts?
10-07-2016, 08:02 PM
2018 30' Flying Cloud
South Hero
, Vermont
I did the paint stripe along the belt line filiform corrosion. I knew that I could never match the silver, so went darker gunmetal gray and "sealed" the paint edge with 1/4" vinyl pinstripe. I think that it looks pretty good and didn't cost much at all.
On an island in Vermont
10-09-2016, 12:46 PM
1976 25' Caravanner
Salt Lake City
, Utah
Looks very nice! A good solution.
10-29-2016, 07:59 PM
2006 25' Safari
St. Augustine
Yes, I like the look and it is an option. The trim option is not difficult. I had a few areas too that had filiform besides the belt line. One area was the stove vent. The corrosion extended out a ways so I ended up buying a stainless stove vent, some Airstream aluminum and making a squared frame of aluminum to go around the stove vent which I riveted on. The other spot was around the teardrop lights.
08-24-2017, 09:32 PM
2007 23' Safari SE
Annandale
, New Jersey
Will be a new owner of a 2007 Safari 23 in couple days, if all goes well.
One of the first projects will be installing the beltline trim that I have noticed on the new 2017/8? 23D's, since the trailer has some filiform corrosion in the back along the belt line seam.
I thought about taking it to a dealer for them to do the work, but the price was well above the cost of a major solar install, so I hope to do this myself.
Fellow I spoke with at the dealership was quite helpful and also quoted a rough materials price of $500 and said that the channel was to be riveted on? Has anyone done this?
08-25-2017, 08:32 AM
Westlake Village
Beltline addition replace from filiform
YES! We had exact same filiform and belt line issue with our then newly acquired 2005 25ft International CCD SS. Got weary of looking at it and decided to do what we could to minimize the "look".
Couldn't find any videos how to do so like a true Airstreamer...did it ourselves. Ha !
Have complete (10min) video of our process and end results. To us, vast improvement on our rig and upgrades the previous look 100%.
Will try and post on YouTube shortly.
Vantair
