Old 03-14-2016, 12:08 PM   #1
montanaandy's Avatar
Installing AC Shroud On A 1978 Landyacht
I tried to do a search on this here on the site but was unable to come up with any information so...
I need to replace what is left of the original AC shroud on the trailer. 15 years of being outside in the Montana weather and crazy mountain winds have left the original shroud in tatters.
I purchased a replacement shroud many, many years ago and it has sat in the garage. The AC still runs well but there is hardly any of the original shroud remaining and it is time to bite the bullet and get up on top of the trailer and put the "new" one on.
Can anyone provide information/insight as to what all is involved with taking the old shroud off and installing the replacement. My recollection is that this is somewhat of a PITA which is in large part the reason I have put this off for so long.
I don't want to dent the trailer crawling around on top of it and I know that there is a specific way to approach this type of repair. Will I have to mess with rivet removal/replacement, caulking etc. How much time and effort does this involve.
I have had 2 hip replacements so I really cannot afford to fall off the roof of the trailer Is this something that I would be better off passing off to a young buck such as my son or my son-in-law because of the degree of difficulty. Thanks in advance.
montanaandy is offline   Reply With Quote
Old 03-21-2016, 06:36 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I'm 65, if that makes you feel any better, and I just did mine over this past winter.
The hardest part was prepping snd painting the new shroud. The old shroud comes off with (4) 1/4" ◊ 20 screws, which I replaced with stainless socket head bolts.
Use a ladder, padded at the top, that rests on the side of the coach just below the awning. I would NEVER try to climb up from the non-awning side. =:0
Once you're up there, unscrew the four rusted screws (PB Blaster?), lift the old cover straight up, and give it a satisfying heave off the roof. (Caveat: You may wish to re-use the extruded aluminum trim band, in which case just slide the old cover down the ladder)
You'll need to measure the bolt positions carefully to drill your bolt holes in the new cover.
I had epoxied the upper and lower halves of the new cover together already, and I just pushed it up the ladder.
To not dent the top of the trailer, put your weight on the ribs, which you can easily identify because that's where the rows of rivets are.
I'm pretty sure I made a thread bragging about the new shroud so just search my name.
Landyacht 30 :: 1998 Airstream Landyacht miltflyfsh Airstream Registry Discussions 0 06-29-2012 04:15 PM
94 airstream landyacht landyacht eBay Watch Airstreams on eBay 0 03-21-2011 08:00 PM
1978 Airstream LandYacht Safari 23 ft eBay Watch Airstreams on eBay 0 04-25-2010 11:50 AM
Curtains: 73 25' Airstream Trade Wind LandYacht vs. 70 23' Airstream LandYacht Safari sysgenss Upholstery, Blinds, Walls & Interior Finishes 1 08-06-2009 12:03 PM
Installing Roof Air Replacement Shroud Kajendo Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-30-2008 12:20 PM
