Old 08-12-2016, 01:58 PM   #1
ChuckZ's Avatar
1966 26' Overlander
Waukesha , Wisconsin
Installing a new electric jack
I am in the process of replacing my 50 year old manual jack on my '66 Overlander and I have a challenge. The original jack has an outer tube diameter of 2". Therefore the lower support plate on my trailer has a 2" diameter. The new electric jack has a diameter of 2 1/4" so I have to enlarge the hole by 1/4". The problem is I'm no metal worker. I'll bet that there is an easy way to do this but I'll be danged if I know. Can someone explain to me how to enlarge the hole?
ChuckZ is offline   Reply With Quote
Old 08-12-2016, 02:15 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
You can get most electric jacks in either tube size.
MICHAEL
Old 08-12-2016, 02:49 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
That is the easy way.
If you are stuck with that jack you could get a plates cut with 2 1/4 in holes, burn out the existing holes and weld the plates in place at the lower hole while the jack is bolted and perpendicular to the tongue. You will not be able to just enlarge the holes and maintain the tight fit necessary on the lower hole by just burning. The upper hole is self aligning because of the 3 bolts.
2004 Excursion 4x4
Old 08-12-2016, 03:32 PM   #4
1976 31' Sovereign
Oswego , Illinois
ON my 76 AS there was a sleeve in bottom hole just knocked out now 2x1/4 no mods needed.
Old 08-13-2016, 03:12 PM   #5
ChuckZ's Avatar
1966 26' Overlander
Thanks.
Old 08-13-2016, 03:14 PM   #6
ChuckZ's Avatar
1966 26' Overlander
Now I just got to figure out how to get the electric lead from the front of the trailer back to the battery in the trunk in the rear. Anybody have any thoughts?
Old 08-13-2016, 04:56 PM   #7
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Just a couple of very quick thoughts - please discard if foolish!
(1) Run news wires in small diam. plastic conduit clipped as needed to the belly pan.
(2) Presume a battery line should run right from your batteries at the back up to the umbilical cord - can you tie into the lines there someplace up near the front? Might be an issue of wires capacity though, I'm not sure. If you went that route you could just use an in line fuse someplace up near the jack.
(3) don't wire to your coach battery. Just put a seven pin plug on the jack connecting to the grnd. and +12v wires and connect to your tow vehicle for power as and when needed.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 08-13-2016, 07:20 PM   #8
1976 31' Sovereign
Oswego , Illinois
Also wired into hot wire for break away swt with in line fuze in jack wire.
Old 08-13-2016, 07:40 PM   #9
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
My previous jack just died one day, I had gkids and could not unhitch easily( i had the backup tool) so just drove the whole unit over to trailer guy, took him 15 minutes and off I went.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Atwood LP/Electric Water Heater Problems (Electric Has Failed) gquake Water Heaters, Filters & Pumps 10 06-29-2014 04:02 PM
Installing a new ultra 3002 electric tongue jack on my 65 Caravel toastie Jacks, Stabilizers, Lifting and Leveling 3 03-15-2007 12:10 PM
For electric for genration hase to be oun for electric RichardT Electrical - Systems, Generators, Batteries & Solar 7 12-05-2005 09:05 PM
New electric jack only works occasionally Zmod Jacks, Stabilizers, Lifting and Leveling 3 06-14-2004 09:09 PM
Electric or Gas electric fridge replacement?? tin can luv Refrigerators 26 03-22-2004 10:50 AM
