Originally Posted by Wayne&Sam
You own an Airstream. You should own a pop rivet tool. Make sure they're aluminum rivets.
And double check to be sure the "
mandrel"** is also
aluminum. They make rivets that have an aluminum outside part and a steel mandrel--bad news where the steel gets wet and eventually leaves rust streaks. I have been known to screw that up.
Hint" the steel mandrels are usually black. The ones you want are aluminum color...
** The 'mandrel' is the pointy, nail-looking thing in the center of a new pop rivet. It's the part you stick into the pop rivet tool that then expands the outer part of the rivet, then breaks off with a "pop" (hence the name of the rivets...)
