12-18-2011, 08:12 PM
#29
RR
, British Columbia
Sale was over on Thur. 15th. Digital temperature reader 57-4554-4. 70% off for $29.99.
Go to the service counter and ask them to honour the sale price. If they still have stock they will give it to you for the sale price.
Good luck
Dave
Originally Posted by Aage
CT=Canadian Tire? If so, what do they call it? I don't see it in their online flyer.
12-22-2011, 04:15 PM
#30
Decatur
Infrared thermometer, which one?
I think I would need an infrared thermometer too, Is there a model that seems to be the choice? I looked on ebay, and there are close to 3000 choices, so any and all suggestions would be appreciated.
Rod & Jane
12-22-2011, 06:35 PM
#31
BEWARE of the CAT
2010 31' Classic
Longmont
Rod & Jane
I've always been a fan of Fluke instruments, so I got this one.
Amazon.com: Fluke 62 Mini Infrared Thermometer: Home Improvement
You can however find both less expensive and much more expensive.
'I went with Fluke because after many years of electronic hobbies, I've decided that is a not a good idea to buy unfamiliar test gear.
Ken
12-23-2011, 12:31 AM
#32
2005 19' Safari
Phoenix
I think Harbor Freight has an infrared thermometer on sale now for around $20 after a discount coupon is applied. Looks a lot like the one pictured above; but the case is a different color, and it is NOT a Fluke.
12-23-2011, 08:51 AM
#33
BEWARE of the CAT
2010 31' Classic
Longmont
One other comment:
While searching around for available options and reading a lot of reviews, I found that some inexpensive ones do not have a laser pointer. To me that would make it a lot more difficult to use properly. You must be very close to what you are measuring to be sure you are on the right spot.
Here is a spec from the Fluke 62. It has a ten to one distance to target diameter ratio. In other words if it is 10 inches from the target, you will be reading the average temperature of a 1 inch diameter circle centered on the laser dot. I don't know if that is typical, but it is something to base a comparison on.
Ken
12-23-2011, 09:15 AM
#34
1975 25' Tradewind
Phoenix
12-23-2011, 10:04 AM
#35
Oswego
While this one is not professional grade and you must be relatively close to the material being measured, this one is small and can fit between the wheel spokes etc. to get a good reading. I have found it to be accurate enough for tire, brake, hub measuring.
It's size is what sold me...just sits in the console, readily available, for gas station impromptu use.
http://www.amazon.com/ThermoHAWK-420.../dp/B0016LFX1I
"All I want in this life of mine..... is some good clean fun" - Little Feat
12-23-2011, 11:01 AM
#36
Yet another use.....
Last winter I had a baffling series of faults in the trailer running and turn lights. I traced it to a breakdown in the insulation between wires in the cable between the trailer and the 7-way connector. The site of the short was hotter than the rest of the cable. This would have been very difficult to trace without the infra-red thermometer.
Nick
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
12-23-2011, 02:42 PM
#37
1978 31' Excella 500
Genoa
, Nevada
I check temperatures of all the brake rotors shortly after heading out to watch for any disc hanging up. Also like to observe the difference in surface temperatures of black trucks and white trucks in the playa sun. Airstream Blue (about 140) just a few dozen degrees less than black (170).
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
12-23-2011, 06:36 PM
#38
Vintage Kin
Corpus Christi
Agree with all of above. Hub, brake, tire is critical.
I had a GRAINGER piece that fitted shirt pocket. Recommend this size, but check before washing machine does its best. Worst.
2004.0 DODGE 2500 QC/LB Cummins 305/555; 6-manual, 7,400-lbs; fuel cost is 25-cpm towing 34' trailer; 15-cpm solo.
Sold: 1983 Silver Streak 3411 Supreme; 6,860# (8,000 GVWR) Currently: 1976 32' SS
Photos prior to sale
02-17-2012, 11:41 AM
#39
RR
, British Columbia
Canada Shopper Alert
Canadian Tire has the new model on sale starting today.
New model includes a stud sensor with the temp. reading. 70% off =$29.99
The link requires a Canadian Postal Code.
You can search for it on their site with #57-4514-0
Dave
Canadian Tire Weekly Flyer
02-17-2012, 01:16 PM
#40
2004 30' Classic
Field and Stream
, PA & MT
I use my Fluke to check water temperatures in the river when I'm fishing.
So my fish catching prowess is based on science, and partly a fluke.
Flyfisher
02-17-2012, 01:18 PM
#41
Vintage Kin
Corpus Christi
Found an non-laser shirt-pocket-clip sized one at Radio Shack for $24.99
02-17-2012, 01:40 PM
#42
1967 30' Sovereign
Angel Fire
, New Mexico
Wellllll, Alton Brown, in his recent episode dealing with chocolate, recommended use of an IR thermometer to monitor the critical temperatures of melting the stuff.
Lynn
WBCCI 21043
| Thread Tools |
| Display Modes |
