Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 07-23-2015, 10:54 AM   #1
ghaag's Avatar
2023 30' Classic
2014 30' FB FC Bunk
Jonesboro , Arkansas
In case you have a flat
I am on my 3rd Airstream and had my first flat. I thought I would pass along what I learned in case it might help someone else. This occurred on a 2014 30' Flying Cloud. First, in case you do not know, (at least my model did not) it does not come with a jack. The manual recommends changing with leveling blocks. I had leveling blocks, but not enough to get my trailer high enough to get the new tire on. I made it to a Walmart and purchased the item below and it was perfect. I would guess you need something to get the good tire approximately 8" off the ground to compensate for the drop in the axle with the flat (see picture below). In all likely hood there is a better way to do this, but this solution worked for me and I hope it helps someone else be prepared in advance.
Safe Travels!
Greg
Name:	Screen Shot 2015-07-23 at 11.52.13 AM.png
ghaag is offline   Reply With Quote
Old 07-23-2015, 11:02 AM   #2
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
I wonder if Lynx blocks would work. I have two sets.
Kelvin
Old 07-23-2015, 11:07 AM   #3
2014 25' Flying Cloud
New Ashford , Massachusetts
Trailer-aid block very handi
Camco Trailer Aid, Black - Walmart.com
Joe D
Dexterpix is offline   Reply With Quote
Old 07-23-2015, 11:14 AM   #4
ghaag's Avatar
2023 30' Classic
2014 30' FB FC Bunk
Kelvin
Kelvin,
There are people on here much more qualified to speak to this issue than myself, but I think they would.
Greg
Old 07-23-2015, 11:15 AM   #5
ghaag's Avatar
2023 30' Classic
2014 30' FB FC Bunk
Joe D
That would have been perfect, Joe! I was in a Walmart in a small town in Alabama and did not see that option.
Old 07-23-2015, 11:40 AM   #6
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Safe Travels!
Greg
That is exactly what I have, but I bought mine at Advance Auto because Advance was within walking distance when I had a flat at the house.
It came as a pair. One is in the shed. The other is in the rear storage compartment under the bed. We have camped on a spot so un-level with the front of the trailer so high that I used it as a first step to enter the trailer
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 07-23-2015, 11:41 AM   #7
m.hony's Avatar
2013 30' Classic
Kelvin
2 sets of Lynx Levelers will git-r-dun.
1 set is not quite enough.
TAC #MS-10
Airforums #70955
Old 07-23-2015, 11:54 AM   #8
2017 30' Flying Cloud
Spotsylvania , Virginia
The Camco Trailer Aid comes in two sizes, buy the one for the 16" wheel and it does the job quite nicely.
KWN306 is offline   Reply With Quote
Old 07-23-2015, 12:16 PM   #9
richinny's Avatar
2011 34' Classic
if you're really in a jam.........
deflating the tire can give a lot more clearance but you'll need a pump to refill the spare.
if you're on soft ground you can dig under the flat tire with a shovel.
Ricky
Old 07-23-2015, 12:52 PM   #10
DKB_SATX's Avatar
Alamo Heights , Texas
I just carry a bottle jack.
— David
Old 07-23-2015, 12:58 PM   #11
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Bottle jack is fine IF you know where to place it. One member here had roadside assistance come to his aid.... and the "technician" put the jack on the belly pan and kept pumping away until it splintered through the floor!
Old 07-23-2015, 12:59 PM   #12
StreamRollin's Avatar
1999 25' Safari
Denver , Colorado
Is it true, I've heard that once you get the tire off that you can ride on just one tire at a reduced speed just to get to the next exit to have tire repaired.
Jim D.
AIR # 56543 TAC# CO-10
StreamRollin is offline   Reply With Quote
Old 07-23-2015, 01:25 PM   #13
Mission , Texas
I've been told a couple of 2x6s (from the odd wood leveling assortment) would be enough.
Bottle jack? No thanks. Only if it has a real base welded to the bottom and a jack stand top. They like to tip over.
Floor jack ... perhaps too big and heavy for most to think about.
nrgtrakr is offline   Reply With Quote
Old 07-23-2015, 01:51 PM   #14
Wise Elder
Jammer's Avatar
2010 30' Classic
I carry the lynx blocks and a bottle jack.
If most of the weight is on the lynx blocks the bottle jack can be used under the axle with the flat, gently, to pick up an inch or two.
Old 07-23-2015, 02:29 PM   #15
Can-o-worms
1970 23' Safari
Howey in the Hills , Florida
How about a scissor jack under the axle? My AS is super light. I've heard of people using the plate that bolts to the frame that the axles are bolted to. Has anyone modified frame to accept a jack?
Bob Riffle is offline   Reply With Quote
Old 07-23-2015, 02:43 PM   #16
2019 26' Flying Cloud
Colorado Springs , CO
Fortunately I haven't experienced a flat on the AS. However, I did purchase the Anderson Rapid Jack. It raises one tire high enough to get the flat one off the ground (I hope).
Here's the Amazon link: http://www.amazon.com/Andersen-Manuf...ZZPEENCF0J4XWC
Losman is offline   Reply With Quote
Old 07-23-2015, 03:03 PM   #17
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I use Andersen Levelers with a 4 inch rise. That is plenty to remove and install a tire on my Safari.
MICHAEL
Old 07-23-2015, 03:30 PM   #18
DKB_SATX's Avatar
You shouldn't jack on the axles themselves. The axle flange (the piece of heavy angle that has the notch(es) for the axle(s) is good for lifting the trailer, but the axle tube can bend.
The flange doesn't really require any modification to use for jacking, just center the top of your jack on the flange and lift.
— David
Old 07-23-2015, 03:49 PM   #19
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I have a few 2x6's that I use for leveling. I think I have enough to raise it high enough to get the wheel off. If not I also carry a bottle jack. I use it all the time when servicing the brakes & bearings etc. AND yes you can drive it a short distance with one wheel removed. Hope that's never necessary but then again " You never know".
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 07-23-2015, 04:37 PM   #20
m.hony's Avatar
2013 30' Classic
Depending on which truck you have, your truck jack may lift the Airstream, especially if you have a 3/4 ton or 1 ton.
My jack in my 1/2 ton won't-
Don't ask me how I know I know-
TAC #MS-10
Airforums #70955
Anyone have tips on mounting flat screen TV up front of a vintage '65? Rocker66 General Interior Topics 3 06-23-2017 06:45 AM
In case you needed convincing that your Airstream is better than a hotel DavidsonOverlander Our Community 3 11-13-2012 04:40 AM
How do you know you've got a flat? Gringo On The Road... 56 12-23-2011 03:09 PM
In case you missed it....Cool stuff and other parts on Ebay Maryw164 Dollars & Cents 6 06-11-2009 04:31 PM
I have a 1965 Caravel and if I have a flat tire toastie Tires 11 09-07-2006 11:51 AM
