Old 07-25-2015, 06:03 PM   #43
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Originally Posted by Rjpuckett View Post
WARNING: Whenever the trailer must be lifted with a jack, as when changing a tire or leveling on very rough terrain, ALWAYS PLACE THE LIFTING JACK UNDER THE MAIN FRAME RAIL. A label is provided to indicate the proper position for the jack. NEVER USE STABILIZING JACKS or HITCH JACK TO LIFT THE TRAILER.
Does not apply to driving up on stacked blocks carefully that are 3 inches high.This is telling you how to use and proper placement of a jack.
Old 07-26-2015, 09:44 AM   #44
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
The Trailer Aid makes it simple and easy to change a tire. Summer of 2014 I had a blow-out on the 401 easy of Toronto. I pulled over and the whole job of changing the tire took less than 15 minutes. Got to the next rest area and fired up the generator and compressor and topped up the changed tire. 3 months later got rid of the 15" ST tires and went to 16" LTX as part of replacing the running gear.
One of the things that is nice about the trailer aid is that it has steel teeth on the flat side to grip the ground so that it doesn't shimmy or slide when you roll up onto it.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 07-28-2015, 10:19 AM   #45
2014 25' Flying Cloud
Dexter , Maine
"One of the things that is nice about the trailer aid is that it has steel teeth on the flat side to grip the ground so that it doesn't shimmy or slide when you roll up onto it." blkmagikca
2nd that, and it's plastic doesn't rot, rust, weight much and it's cheap. never understood why people fell it is nessecary to build something or use something for a purpose it is not best suited for just to save a couple bucks, but are more that willing to spend untold amounts of $$ on something frivalous.
Joe D
Dexterpix is offline   Reply With Quote
Old 07-28-2015, 03:09 PM   #46
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
The "bending" of the axle refers to crushing the tube not flexing it. Even a slight indentation of the tube would totally mess up the way the rubber insides of the axle work.
Gearheart is offline   Reply With Quote
Old 07-28-2015, 04:22 PM   #47
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I carry a bottle jack. I have a little saddle that is made up of a short pice of round tubing that fits over the jack that is welded to a little pice of u tubing that fits around the trailer frame between the wheels. Keeps the jack under it well. Lifts both wheels quickly and easily. For me the Links blocks slide on the asphalt instead of letting the trailer climb onto high enough stack of them.
Old 07-28-2015, 06:49 PM   #48
Houston , Texas
I am coming from an enclosed car trailer, but I have always worried that anything that lifts the trailer with one wheel might overload the tire or axle. Is that not a worry here?
WayneS is offline   Reply With Quote
Old 07-28-2015, 07:08 PM   #49
Piggy Bank's Avatar
2017 25' Flying Cloud
2015 22' FB Sport
Kansas City , Missouri
So what about us with single axel trailers? Recommendations?
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 07-28-2015, 07:23 PM   #50
K.C. , Missouri
First, what I would say is buy the best tires of sufficient load capacity you can to mitigate the likelihood of needing to change a tire, and second, I would think most any trailer that is single axle could easily be lifted up with the jack from the tow vehicle. Try it in the driveway first ?
gmw photos is offline   Reply With Quote
Old 07-28-2015, 07:53 PM   #51
Images: 59
In addition to having good tires, if you have a single axle trailer a TPMS system is great to have. Saved my bacon at least once.
My Tahoe has a screw jack that works fine, but as stated above, try it in the driveway first. The side of a dark country road is no place to learn.
Old 07-29-2015, 06:34 AM   #52
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I don't know if maybe they have changed the design of the Lynx levelers, but I use mine on asphalt all the time when repacking wheel bearings and have never once had them slide on me. When I first got them I was concerned that they might, but they just never have done ..... yet.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 07-29-2015, 08:24 PM   #53
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I have had Lynx levelers slide-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 07-29-2015, 08:36 PM   #54
Moflash's Avatar
Mine don't slide...
Anyone have tips on mounting flat screen TV up front of a vintage '65? Rocker66 General Interior Topics 3 06-23-2017 06:45 AM
In case you needed convincing that your Airstream is better than a hotel DavidsonOverlander Our Community 3 11-13-2012 04:40 AM
How do you know you've got a flat? Gringo On The Road... 56 12-23-2011 03:09 PM
In case you missed it....Cool stuff and other parts on Ebay Maryw164 Dollars & Cents 6 06-11-2009 04:31 PM
I have a 1965 Caravel and if I have a flat tire toastie Tires 11 09-07-2006 11:51 AM
