Old 07-23-2015, 02:29 PM   #15
Can-o-worms
1970 23' Safari
Howey in the Hills , Florida
How about a scissor jack under the axle? My AS is super light. I've heard of people using the plate that bolts to the frame that the axles are bolted to. Has anyone modified frame to accept a jack?
Bob Riffle is offline   Reply With Quote
Old 07-23-2015, 02:43 PM   #16
2014 25' Flying Cloud
Colorado Springs , Colorado
Fortunately I haven't experienced a flat on the AS. However, I did purchase the Anderson Rapid Jack. It raises one tire high enough to get the flat one off the ground (I hope).
Here's the Amazon link: http://www.amazon.com/Andersen-Manuf...ZZPEENCF0J4XWC
Losman is offline   Reply With Quote
Old 07-23-2015, 03:03 PM   #17
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I use Andersen Levelers with a 4 inch rise. That is plenty to remove and install a tire on my Safari.
MICHAEL
Old 07-23-2015, 03:30 PM   #18
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Originally Posted by Jammer View Post
I carry the lynx blocks and a bottle jack.
If most of the weight is on the lynx blocks the bottle jack can be used under the axle with the flat, gently, to pick up an inch or two.
You shouldn't jack on the axles themselves. The axle flange (the piece of heavy angle that has the notch(es) for the axle(s) is good for lifting the trailer, but the axle tube can bend.
The flange doesn't really require any modification to use for jacking, just center the top of your jack on the flange and lift.
— David
Old 07-23-2015, 03:49 PM   #19
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I have a few 2x6's that I use for leveling. I think I have enough to raise it high enough to get the wheel off. If not I also carry a bottle jack. I use it all the time when servicing the brakes & bearings etc. AND yes you can drive it a short distance with one wheel removed. Hope that's never necessary but then again " You never know".
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 07-23-2015, 04:37 PM   #20
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Depending on which truck you have, your truck jack may lift the Airstream, especially if you have a 3/4 ton or 1 ton.
My jack in my 1/2 ton won't-
Don't ask me how I know I know-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 07-23-2015, 04:43 PM   #21
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Originally Posted by ghaag View Post
Kelvin,
There are people on here much more qualified to speak to this issue than myself, but I think they would.
Greg
Two sets of Lynx levelers is what we have always used.
I carry a bottle jack as well - mainly in case we have problems with our tongue jack, but for changing a wheel I feel safer using the lynx Levelers.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 07-23-2015, 05:16 PM   #22
B00merang's Avatar
2010 20' Flying Cloud
Hailey , Idaho
Jammer is right...you want to spread out the weight. I keep a 2-ton scissor jack (25 lbs) in the rear compartment with a 6"x6"x2" block. Just make sure to keep the jack from rolling and center the wood block on the AS' jack plate. I found this to be stable arrangement for my tire changes. jon
B00merang is offline   Reply With Quote
Old 07-23-2015, 06:47 PM   #23
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Originally Posted by StreamRollin View Post
Is it true, I've heard that once you get the tire off that you can ride on just one tire at a reduced speed just to get to the next exit to have tire repaired.
Take off the wheel if you can. If you can't you can still tow for a limited distance it if you are ok with sacrificing the tire. Go real slow so the tire won't tear up your wheel well when it comes apart.
Old 07-23-2015, 06:58 PM   #24
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Folks,
Many tow with 1/2 or 3/4 ton pickups. The jack supplied with the truck deserves a look for use lifting your AS.
I have a 30' S/O pretty heavy and I've raised one side of it with the Jack that came with my 3/4 ton pickup.
I found a jack from a 1 ton pickup it has a bigger base and does a great job of lifting the AS.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 07-23-2015, 07:06 PM   #25
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
In case you have a flat
I use Lynx blocks on my 28ft whenever I need to remove tire/ wheels for wheel bearing servicing lifting one wheel at a time then backing up to lift the next one.Easy deal ...one set is all you need to do this.
Old 07-23-2015, 07:24 PM   #26
Rjpuckett's Avatar
2012 25' Flying Cloud
San Antonio , Texas
My AS has jacking points that are there for raising the trailer. Using the axel as a raising point will damage the intended curve of it. This is also important to point out to anyone else trying to jack up your trailer (new tires, etc.)
Rjpuckett is offline   Reply With Quote
Old 07-23-2015, 07:44 PM   #27
Moflash's Avatar
This is not true.If it was then every speed bump that you went over slowly along with every bump in the roar that you went over would bend the axle.
If don't jack up all four corners at the same time with 4 bottle jacks u are loading the axles or putting undo stress on your trailer frame and TV hitch also.
Common sense goes a long way.You can't leave one axel on blocks for months nor would lift higher than u need to remove the tire and wheel.
Old 07-23-2015, 07:53 PM   #28
hugheym's Avatar
1961 16' Bambi
1969 27' Overlander
Bonner Springs , Kansas
Hi all,
I carry a Trailer Assist, a simple ramp that is easy to store. I think I purchased mine from Camping World. I also carry a 12v air pump and a 12v impact wrench. Shoulder problems make it necessary to have these helps along.
Martin
hugheym is offline   Reply With Quote
Anyone have tips on mounting flat screen TV up front of a vintage '65? Rocker66 General Interior Topics 3 06-23-2017 06:45 AM
In case you needed convincing that your Airstream is better than a hotel DavidsonOverlander Our Community 3 11-13-2012 04:40 AM
How do you know you've got a flat? Gringo On The Road... 56 12-23-2011 03:09 PM
In case you missed it....Cool stuff and other parts on Ebay Maryw164 Dollars & Cents 6 06-11-2009 04:31 PM
I have a 1965 Caravel and if I have a flat tire toastie Tires 11 09-07-2006 11:51 AM
