Old 09-13-2011, 11:02 AM   #1
2012 23' FB International
Hollister , California
I'm on edge!
Just had my first outing in my 25/FB/Inter and had a wonderful time. But one annoying thing happened on multiple occasions; kept cutting myself on the edges of the dinning table and counters due the very sharp edges! Cant believe AS allows this. Most furnishings of this sort are bull nosed or beveled when built. Am planning on using a Dremmel to smooth the edge but dont want to chip or delaminate the Formica. Anyone tried this or has a better solution?
Luftnoggin is offline   Reply With Quote
Old 09-13-2011, 11:19 AM   #2
Ottawa , ON
Well, without the benefit of seeing what you are trying to describe, I would start with a very fine sandpaper before going all Dremel on it.
Will you post some photos? If you camera has a macro button (symbol looks like a little flower usually) a real close-up or two would be good.
Old 09-13-2011, 11:27 AM   #3
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We had the same problem and added anodized aluminum counter edging to all those surfaces... We added to every edge that was an issue...even the tops of drawer faces. Not only did it solve the issue, it dressed up the Bambi nicely...
We got it at Ace in 6' lengths, pre-drilled and with screws for installation, but not all stores carry it. The product is M-D Counter Moulding A-813...the ACE skew # is 0 43374 69450 0...the "69450" is the important part. I believe you can also get it online at Amazon.com...
Name:	Aluminun Edge_03_Sm.jpg
ID:	140098   Click image for larger version
Name:	Aluminun Edge_02_Sm.jpg
Name:	Aluminun Edge_01_Sm.jpg
ID:	140100   Click image for larger version
Name:	Aluminun Edge_04_Sm.jpg
TB & Greg and Abbey Schnauzer
#3954
Old 09-13-2011, 01:02 PM   #4
1974 Argosy 22
1976 Argosy 28
1972 Argosy 24
Chico , California
if it is a laminate square edge, use a file at a downward angle, pushing from top down. go lightly, it will take the sharp edge off. about a minute of time should do it. I worked a lot with laminate counters, that was the finishing touch on every job.
twilder is offline   Reply With Quote
Counter and Table Edge Trim perryg114 Cabinets, Counter Tops & Furnishings 28 10-30-2011 11:21 PM
Show a snapshot from your Airstream window! missysanford On The Road... 64 09-17-2011 12:02 PM
Edge Insight CTS to monitor vitals texascanuk Towing, Tow Vehicles & Hitches 1 08-25-2011 01:45 PM
Supposed to be drip edge on Driver's Side? Johns5711 Land Yacht/Legacy Motorhomes 6 08-03-2011 05:03 PM
Edge banding or molding ALANSD Cabinets, Counter Tops & Furnishings 16 06-15-2011 05:54 AM
