Old 07-13-2013, 08:56 AM   #1
jenner 515's Avatar
1970 25' Caravanner
Arvada , Colorado
I'm not sure what to call these. But I need new ones.
Working on the 70 Carravaner.
Where the hitch assembly comes out from beneath the body...some sort of gasket or boot.
Long since dried up and blown away. What are they? Where can I find some? What can I fab them out of?
jenner 515 is offline   Reply With Quote
Old 07-13-2013, 09:03 AM   #2
Rich of SCal's Avatar
2012 16' Sport
San Bernardino , California
I would probably just seal it with some Vulcan 116. It stays flexible and the gray would look ok next to the aluminum. Very handy stuff.
Rich of SCal is offline   Reply With Quote
Old 07-13-2013, 09:10 AM   #3
That part has been obsolete for about 25 years.
Remove the old stuff and fill in the area with Vulkem sealer.
Old 07-13-2013, 10:06 AM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I made couple out of a flexible roofing material (Fibertite) Need to get a couple of pictures to post. The best alternative is to use vulkem and leave the bottom of the aluminum panel open so water can drain out if it gets in.
Aaron
WBCCI #XXXX AIR #2495
Old 07-13-2013, 12:44 PM   #5
2012 16' Sport
Old 07-15-2013, 05:59 AM   #6
jenner 515's Avatar
1970 25' Caravanner
Arvada , Colorado
Sealed them up and crafted new booties.
Thanks for the advice folks.
Old 07-15-2013, 06:02 AM   #7
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
That looks really nice! What did you make the booties out of?
Old 07-15-2013, 06:09 AM   #8
jenner 515's Avatar
1970 25' Caravanner
Arvada , Colorado
Rubber stair tread material for exterior stairs.
Old 07-15-2013, 11:51 AM   #9
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Great idea, that is similar in thickness to the roof material I used. But mine is a gray color. I like how yours blends in with the frame color.
Aaron
Old 07-15-2013, 12:13 PM   #10
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Vinyl Baseboard Molding
You can also use vinyl baseboard molding designed for use with vinyl tile and sheet goods in commercial applications.
Using a hot air gun, you can shape the base molding into a U-Shape. With the flanged edge to the rear up against the exterior skin of the Airstream, they almost look like OEM. Many colors available including black and battleship gray.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Close Call crane422 Plumbing - Systems & Fixtures 14 01-25-2012 04:34 PM
SilverPal ... Call me arstremr Airstream Lifestyle 0 12-23-2011 04:14 PM
Call for pics LI Pets Airstream History 1 10-26-2011 06:46 PM
When to Call in a Pro? Airstream Dad Repairing/Replacing Floor &/or Frame 8 09-29-2011 02:46 PM
Dame Marjorie Chardin (but you may call her Maude) :: 1974 Airstream Argosy dreamtupelo Airstream Registry Discussions 0 08-19-2011 08:31 AM
