Old 11-05-2014, 05:44 PM   #1
Starstream's Avatar
Spring , Texas
If You Could Do a Re-Do?
If you could do something different on your AS update or restoration. What would that "thing" or "things" be and why?
Starstream is offline   Reply With Quote
Old 11-05-2014, 07:54 PM   #2
Rollster's Avatar
Saint Augustine , Florida
Though I initially liked the looks of our Allure floor, it isn't holding up all that well - scratches too easily and edges are susceptible to coming up. I'd use marmoleum or Beauflor instead.Click image for larger version
Name:	ImageUploadedByAirstream Forums1415238798.719111.jpg
This is a picture of the floor during our conversion from queen to twin beds.
Carol, Aboard "Aggie the DreamStream"
WBCCI# 5248
Rollster is offline   Reply With Quote
Old 11-05-2014, 08:07 PM   #3
terryV's Avatar
2002 31' Classic
Monroe , Iowa
My wife wants to remove the carpet in our '02 Classic and put in a "wood" floor.
I noted your choices above. Is there a reason you didn't mention the bamboo flooring?
Also, would you recommend guting the interior to lay the flooring?
terryV is offline   Reply With Quote
Old 11-05-2014, 08:45 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
There is a lot I would do different, but There is nothing major that I would change.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 11-05-2014, 08:54 PM   #5
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
We installed bamboo flooring in our house - supposedly the toughest kind available. Never again. It scratches way too easily in our house, and I'm sure it would be even worse in a TT that we take camping where all kinds of dirt gets tracked in and then stepped on before it can be swept up / mopped out.
Rocinante is our 2014 International Signature 27FB
Old 11-05-2014, 09:04 PM   #6
frscott's Avatar
1986 25' Sovereign
Wichita Falls , Texas
I put in a tankless water heater, would not do that again. And when i replaced my skylights with fans I would have used two tubes of sealant on each!!! (they leak)
frscott is offline   Reply With Quote
Old 11-05-2014, 10:57 PM   #7
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I installed a residential tankless, over a year now and so far so good.
I love the ability to take an endless shower. It is so boss.
Old 11-05-2014, 11:56 PM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I have installed flooring from 'Lumber Liquidators' (LL). It has been flawless. It all snaps together very snug.. has had ZERO problem 'coming apart' or wrinkling... Good stuff.
PM for pics if you want. We did NOT pull out the furniture..
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-06-2014, 11:12 AM   #9
frscott's Avatar
1986 25' Sovereign
Tankless
"I installed a residential tankless"
I had not though of looking into a residential...May try that, mine just alternates from hot to cold--OK if you get the timing down!!
Scott
Old 11-06-2014, 11:42 AM   #10
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
On this particular trailer?
1. I would have bought from Foley in Gulfport, MS.
2. I probably would have special ordered rather than buy from dealer inventory.
3. twin beds for more storage, easy access to storage, easy to walk through, easy to make the bed-
4. 16" wheels and LT tires
5. ProPride 3P
6. brown (or whatever they call it) ultraleather
7. solar
8. inverter
9. all stainless options- water fill area, storage on street side, furnace cover, water heater cover, range hood vent
10. 4 or more AGM batteries
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 11-06-2014, 02:12 PM   #11
1978 31' Excella 500
Barrie , Ontario
I would have NEVER taken my AS to a non AS repair shop total ripoff !!!!
Bev1940 is offline   Reply With Quote
Old 11-06-2014, 05:14 PM   #12
Rollster's Avatar
For the reason stated about scratching too easily, we didn't consider bamboo, but we have heard good reviews from people on the forum about cork. We almost bought the BeauFlor since it's what AS now uses (as well as many other RV manufacturers), but it's sold in big sheets and needs to be adhered with a particular glue, and being neophytes, we thought it might be difficult to lay.
We did gut the bedroom to lay the floor since we were revamping the beds anyway, but in the main salon, we only removed the couches and dinette, but trimmed around the kitchen cabinets. In the head, we removed the toilet but trimmed around the bathroom vanity.
Good luck with your project!
WBCCI# 5248
Old 11-06-2014, 08:23 PM   #13
Starstream's Avatar
Spring , Texas
7. solar
8. inverter
What size solar power system would you put in?
What size inverter would you put in?
And what size batteries would you put in?
Old 11-06-2014, 08:45 PM   #14
m.hony's Avatar
2013 30' Classic
I don't know enough about it to say, but BIG!
As many panels as,would fit on the roof-
As big as they make batteries and inverter-
TAC #MS-10
Airforums #70955
If you could anywhere from Seattle, where would you go? J5MM On The Road... 27 03-19-2011 09:37 PM
If you could move 76sovereign Fun & Games 5 06-30-2009 05:41 PM
Could you look at this unit please? connorsa Full-Timing 1 06-28-2009 10:18 AM
I say there 'ol chap, could you pass the... krowsea Cabinets, Counter Tops & Furnishings 7 10-22-2004 08:54 PM
