06-24-2017, 08:34 AM
#161
Registered User
1957 22' Custom
Lago Vista
Bending the 'F' Channel Aluminum
I bought aluminum extrusions in an 'F' shape from VTS to hold the wall panels, and bending them hasn't gone well. I'm using the old wall panels to bend the extrusions into shape, then heating them to annealing temperature so they'll hold the shape, but the problem is the rivet side of the extrusion bends a little further towards the center of the curve than the two fingers of the F. The effect is that one side of the extrusion is tight against the inner skin, but the rivet side won't suck up to the skin no matter how many rivets I use. On the curbside cabinet it won't be a problem, no one will ever see the problem because the bad side will be inside the cabinet. The wet bath is a problem, though, because both sides of the extrusion will be visible. I thought about caulking it with gray caulk, but that just feels like a coverup for poor workmanship. I'm not sure what to do...
06-24-2017, 09:44 AM
#162
Central
, Mississippi
I Love Lucy
That F channel is a bear to get bent! I made a slotted die that helped
06-24-2017, 10:42 AM
#163
Registered User
1957 22' Custom
Lago Vista
Well, there you go
See? This is why you hang out here: you learn stuff. Off to make a die and a better bend. Thanks HiHo!
06-24-2017, 07:32 PM
#164
2016 30' International
Calgary
, Alberta
Originally Posted by DDickey
It was so fast and easy I thought I was doing something wrong. Clamping it and bracing it is important, but that's easy to do. It's cost effective, efficient, and I really like working with it.
Good to hear, have had the same experiences with it!
Michael and Leah
2016 International Serenity 30'- "Suburban Cliche"
2017 F350 Lariat
Poodle and two cats!
06-24-2017, 07:34 PM
#165
Calgary
, Alberta
Would grinding a little material off the outside of the 90 corner help?
Michael and Leah
2017 F350 Lariat
06-25-2017, 06:10 AM
#166
1956 22' Caravanner
Don Pedro Island
That is my thought process also...When installing boat s/s rub rails we use to score the metal (part you did not see) and then work the bend. I do like the die concept.
06-25-2017, 06:42 AM
#167
Registered User
1957 22' Custom
Lago Vista
Grinding/Cutting
I'm not sure if grinding or cutting would help - it might. It's almost as if each side wants to bend at a different rate, the 'drop' in the F bending faster than the fingers. I'm going to try the die first and report back...
06-25-2017, 09:48 AM
#168
Central
, Mississippi
Yup. The drop in the F makes the part twist as it bends. A pure U shape doesn't do that.
Even with the die its a pita but without a die all my efforts resulted in a wonky mess. Interestingly, in '61, the extrusion has a wing on both sides and it bends much straighter.
06-25-2017, 04:43 PM
#169
Registered User
1957 22' Custom
Lago Vista
I made the die
and it works. It's not perfect, but along with a torch, a rubber mallet, and a small sledge hammer I got the thing to bend without much of a twist. I'm thinking about pulling the ones I've already installed and re-doing them. I've done quality work on Lucy so far, and the details matter to me.
My trailer's original extrusions had a wing on both sides, and I bet that would be much easier to bend. VTS doesn't sell that shape, and I had already bought all the the F shape I needed from them before I knew how hard it was to bend or I would have searched for the other shape elsewhere. Bending and installing the wall extrusions has been one of the more difficult processes in rebuilding this trailer.
06-26-2017, 07:02 AM
#170
1956 22' Caravanner
Don Pedro Island
What is a "wing" ?
06-26-2017, 08:58 AM
#171
Registered User
1957 22' Custom
Lago Vista
Extrusion Shapes
Originally Posted by islandtrader
What is a "wing" ?
Hey islandtrader,
It's the way we're describing the original extrusion. The original has 'wings' on both sides of the 1/4" channel. The extrusion VTS sells only has a wing on one side, making it similar to the letter F. When you try to bend the F shape it also wants to curl in the direction of the drop in the letter F. The symmetry of the original extrusion would make it easier to bend. If I had to do it all again, I'd buy extrusions in the original shape from some other supplier - they're not hard to find.
06-27-2017, 05:35 AM
#172
1956 22' Caravanner
Don Pedro Island
Thanks, the only reason I can see for the F design on a flat surface you could make a cleaner looking finish (meaning not seeing rivets on the outside surface).
06-30-2017, 08:15 AM
#173
Registered User
1957 22' Custom
Lago Vista
More plumbing and bath
I had Custom Sheetmetal bend up a wall/cabinet piece out of 24ga 304 stainless. We took into account the 1/4" problem with the pan that I posted about awhile back and it's going to work perfect. The interior of the bathroom is going to be 304 stainless steel on all the walls, a Corian countertop and a teak floor to keep your feet dry since it's a wet bath.
I've also installed the 30 gallon fresh water tank and a new filler from VTS. The fresh water system is now 100% and tested, as is the drain system. I want to scab in the electric for my water heater so I can fire it up and see if my gravity hot water circulation system works. Gravity hot water circulation systems work best on two story buildings, so I'm not sure if the physics will allow my little system to work, we'll see. If there's not enough oomph to create circulation I'm going to add a push button pump and that will give me instant hot water.
07-01-2017, 06:57 AM
#174
1956 22' Caravanner
Don Pedro Island
Some Buffing
I don't know...that water inlet looks like it needs a good buffing and polishing to keep up with the rest of the trailers shine
Everything is looking pretty tight. I know I'm about a year behind on where your at, however its kinda a nice to see how my trailer will "look" cause we have similar ideas.
The picture of the bath is great. As you know I'm mirroring yours: mine is CS and is behind the wheel well, yours is the opposite.
07-02-2017, 08:07 AM
#175
Registered User
1957 22' Custom
Lago Vista
Thanks islandtrader!
It wouldn't be looking near as good without your help on the front end cap! RE: filler neck - I'm actually thinking about pulling it back out and having it chromed. My dad used to tell me, 'if the chrome don't shine, the motor won't go.'
The bath has been complicated and slow going, but I want to get it right. Now I'm trying to figure out how to get 1/4" plywood clad with 24 gauge stainless steel to fit in the 1/4" F channel, hmmmmmmmmmmmmm
07-02-2017, 08:00 PM
#176
1956 22' Caravanner
Don Pedro Island
Thanks, and you have paid back with your help.
The water filler if aluminum can be polished out to look like chrome. Heck send my way I won't charge too much haha.
07-04-2017, 09:20 AM
#177
Registered User
1957 22' Custom
Lago Vista
Bending the F Channel
Tools Needed:
1. Jig
2. Sledge Hammer
5. rubber Mallet
6. Torch
7. Laser Thermometer
8. Work Surface
9. Blocks
Process:
Screw jig to work surface, clamp channel with block, heat, bend and hammer until you're happy with it.
Notes:
1. You need the thermometer to make sure you don't overheat the aluminum, or it'll melt. I heated to about 500F.
2. You really do need a sledge hammer, you have to knock the hell out of it to get it into the right shape.
3. The rubber mallet is for hitting areas that will show.
4. I made my jig fit the wall exactly, but the aluminum springs back a bit. Next time I'll make the jig with a slightly tighter radius than I need. Not a big deal
07-04-2017, 12:29 PM
#178
Central
, Mississippi
Now THAT is cool!
07-05-2017, 11:47 AM
#179
Registered User
1957 22' Custom
Lago Vista
Thanks!
Thanks HiHo, it was your idea and it worked like a charm. It takes a lot of elbow grease, manipulation and patience, but once installed it looks great! I'll post a pic when I can get around to it
07-06-2017, 08:45 AM
#180
Registered User
1957 22' Custom
Lago Vista
The F channel difference
Here's the difference between bending with heat and a die, and bending by hand. The first pic is the die bent piece, and it's snugged up nicely agains the skin. The second piece is the hand bend channel, and you can see how the drop in the F wouldn't snug up against the skin because it was twisted. The other side of this channel looks great, and it's the side you'll see. The third pic is how I'm going to fix the two channels that I installed before I figured out how to do it, and that's to stuff them with putty. I'm OK with this only because they're inside the wardrobe/refrigerator cabinet and you'll never see them. They'll bug me for awhile and then I'll forget about them.
