Old 03-31-2012, 12:55 PM   #1
PopHetzler
Emh142's Avatar
2003 34' Classic S/O
Troy , Ohio
I have a strong mildew smell coming into the rear Bedroom of my 34 foot classic.
A strong mildew smell is coming from the outside rear compartment. Any suggestions on cleaning solutions that will kill the mildew?
Emh142 is offline   Reply With Quote
Old 03-31-2012, 02:13 PM   #2
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Ventilation. Open the vents and windows. Put out shallow pans of household bleach. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 04-01-2012, 10:33 AM   #3
PopHetzler
Emh142's Avatar
Troy , Ohio
Thanks for the reply. What about scrubbing and all that stuff?
Old 04-01-2012, 11:58 AM   #4
Triple M's Avatar
2005 19' International CCD
Upton , Massachusetts
You could also run a dehumidifier on humid days.
Triple M is offline   Reply With Quote
Old 04-01-2012, 12:21 PM   #5
Baltimore , Maryland
Just my two cents...
You have a leak. Stop the cause before you treat the result. In that era, leaks should be taken very seriously.
Old 04-02-2012, 01:03 PM   #6
Reganzo's Avatar
2006 34' Classic S/O
Lakewood , New Jersey
I agree with 62Overlander, I had a mildew smell and I found major floor rot under the beds across the whole back wall, curve to curve. The leak in my case was the back window, and it let water run undetected between the shell, and rotted the floor.
Regards,
Reganzo
Reganzo is offline   Reply With Quote
Old 04-02-2012, 02:35 PM   #7
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I too had mildew smell. I too had leaks (and a couple of mushrooms, I might add!) You probably have something going on there.....
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 04-02-2012, 02:45 PM   #8
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
It's a leak.
A dehumidifier from Lowes or other will help cut down on the smell (which is a problem, too, not just the leak itself), and you'll be glad you've run it. You'll get to the leak when you get to it, but the use the D-H constantly to keep the interior dry otherwise. Assume water has infiltrated, and that the compartment may not be near the leak entrance, it may be a ways away.
I leave out open pans of ammonia to help with odors. Cheap. Try [2] and change them every other day.
Old 04-03-2012, 06:26 AM   #9
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Don't know about mildew in a trailer, but here in metro New Orleans mildew is a constant enemy. One thing that works well for me is Pine-Sol (in about double the concentration listed on the bottle), which has the added benefit that while it's killing the mildew, it also covers the smell.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Doing full monte on my '58 Traveler Chlyman 1958 Traveler 77 06-13-2013 07:36 PM
Things that go bump in the night rebelstand Tires 27 04-03-2012 06:29 PM
The Throne and The 23FB murreywalker 2009-2015 Flying Cloud 27 04-01-2012 01:07 PM
Of Mice and Mint Globie64 General Repair Forum 5 03-31-2012 10:11 AM
storage of plates,bowls etc terryandann Airstream Lifestyle 15 03-30-2012 11:40 PM
