Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 10-08-2007, 01:20 PM   #1
Deadhead58
Deadhead58's Avatar
Profile:  2007 16' Bambi
Huntington Beach , California
I can't be the only one
who has driven away with the electric cord attached!
It broke out the plastic shield that holds the plug in place on the body. Where can I get a new one? Who can I talk to???!!
thanks for your help!
Deadhead58 is offline   Reply With Quote
Old 10-08-2007, 01:35 PM   #2
moosetags
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
First off, welcome to the Forums. We're glad to have you with us.
I haven't done that one, yet. But I have done plenty of other similar stupid things. It's all part of Airstreaming. You get so focussed on checking one thing, you overlook something very obvious.
The piece that you "removed for inspection" is standard RV fare. You should be able to find one at Camping World or just about aby RV dealer.
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 10-08-2007, 01:41 PM   #3
Deadhead58
Deadhead58's Avatar
Thank you!
Well thank you very much! I was the one at the drive-in driving away with the little speaker attached to my car window!
I wish I knew what it was called. I'll check the local RV stores.
Old 10-08-2007, 02:10 PM   #4
Ganglin
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
7-Way Sockets and Accessories
Check up to five results to perform an action.
larger image
  • Meets and exceeds all standards of SAEJ560 (Solid Pin Sockets only)
  • Floating pins for ease of alignment and Maximum Contact
  • Self grounded. (Die Cast only)
  • Optimum slant mount and drain slot rid housing interior of accumulated moisture.
  • Will accept the widest range of gauges from #16 wires to #8 ground wire. Ground Terminal Pin #1 will accept #14 gauge min. to #8 gauge max. Other terminals will accept #16 gauge min to #10 gauge max.
  • 40 amps continuous duty @ 6-28 VDC.
  • Self grounded (Die Cast only) to #1 Ground Terminal
  • Stainless steel spring
  • Recommended Moutning Hole = 2" Dia.
  • Interchangeable with all competitive makes.
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 10-08-2007, 02:43 PM   #5
crazylev
LEV ZEPPELIN
crazylev's Avatar
Profile:  2004 19' International CCD
Chicago , Illinois
I think deadhead needs/is talking about the shore power 30 amp coupler with the little hatch door that goes to the cord.
I'd contact the AS store and see if you can pick one up there. The ones I've seen are white plastic, but AS uses a gray plastic. Matches the AS better.
Jonathan
I'm out of my mind right now, but will be returning shortly......
crazylev is offline   Reply With Quote
Old 10-08-2007, 03:03 PM   #6
Deadhead58
Deadhead58's Avatar
crazylev is right
It is grey. Airstream store? I called a local Airstream dealer. They said "power inlet" - $88 and change + shipping! Can't just get the broken piece!
Old 10-08-2007, 03:08 PM   #7
FreshAir
FreshAir's Avatar
Profile:  1966 24' Tradewind
Placerville , California
Welcome to our 'little' group. We enjoy hearing new ideas, questions and stories. No I haven't driven off without disconnecting everything...yet. But my Dad did. It is one of my favorite stories of our family's RTE 66 'pioneer' journey to Calif. from Michigan. The year was 1952. A very hot late June and late afternoon somewhere in Oaklahoma. We needed to stop for the night but there were no overnight trailer parks near. Dad stopped at a dusty RTE 66 roadside service station for gas and directions to a place for the night. The s-station owner said there was nothing for many miles but we could pull behind the station for the night and hook up to water and use the station rest room. Travel trailers then had no holding tanks even though most had full bathrooms. Anyway the next morning continuing on our journey about 10 or so miles west from there a passing car signaled us that we had a problem at the rear of our trailer. Dad found a safe pull off space and we discovered 50' of garden hose still fastened to our trailer....the service station hose. Dad and I unhooked the trailer and after rolling up the hose drove the 10 miles back to return it and pay for the damage. That was the kind of man my dad was. The picture is of our RTE 66 rig taken in Calif. A 1948 Nash Ambassador and a 1950 26' Pan American trailer.
Name:	1952... car & trailer.jpg
Neil and Lynn Holman
FreshAir #12407
Avatar;
Moonrise - Sunset
October 13, 2008
1966 Trade Wind
455 cid
Old 10-08-2007, 03:18 PM   #8
crazylev
LEV ZEPPELIN
crazylev's Avatar
Chicago , Illinois
Deadhead.
I think the AC adapter thing is made by a company called Marinco.
I found this at their website Replacement Cap & Bezel for 30A Power Inlet
or this:
30 Amp Standard Power Inlet
It might be worth a call to find out if they can supply you with a gray one, or know who can. Otherwise pay the piper.
Jonathan
Old 10-08-2007, 05:08 PM   #9
Jaxon
E Pluribus Aluminus
Jaxon's Avatar
Profile:  2005 30' Classic
Heck, go to an RV store, buy a white one cheaper and then spend a couple of bucks on some paint specifically for plastic... color it purple... red, grey or even SILVER, Then call it Airstream.
Bill & Kim's Marvelous Adventure
with Catahoula Charlie
30' Classic
F250 Diesel
AIR 9218
Jaxon is offline   Reply With Quote
Old 10-08-2007, 05:38 PM   #10
Chaplain Kent
Chaplain Kent's Avatar
Profile:  Wauwatosa , Wisconsin
Welcome to the forums. Please don't feel bad as each of us has done something similar or worse. I can't think of which one of my many stories to tell you about so will relate the most current one. My son and I hitched up our Saturn which we flat tow behind our MH one morning and took off through the mountains of Vermont. A friendly couple passed us on the interstate waving and honking and I waved back. They then started pointing and shouting and my son, who was driving at the time, realized they were being more than friendly and pulled over. I stepped out to see what, if anything, could be wrong. and found our Saturn being towed only by the safety chains! We had forgotten to put in the cotter pins which hold the tow bar to the base plate. And I am supposed to be the experienced camper showing my son the ropes.
How about some more confessions to make this new member feel better.
Chaplain Kent
1982 280 Turbo Diesel Motor Home (Chummy)
http://www.fuzzytravel.com/grandakent/
Chaplain Kent is offline   Reply With Quote
Old 10-08-2007, 06:44 PM   #11
Gunnyusmc
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
power inlet
If you check Marinco's web page, they have in in Stainsteel for $98.51.
Don
Gunnyusmc is offline   Reply With Quote
Old 10-08-2007, 08:10 PM   #12
LJH
LJH's Avatar
Profile:  1985 27' Sovereign
Defiance , Ohio
GREAT story FreshAir!
LJH is offline   Reply With Quote
Old 10-08-2007, 09:25 PM   #13
moosetags
moosetags's Avatar
Freshair, that is an absolutely great story. Your Dad was a very honorable man.
