Old 10-09-2014, 08:51 PM   #15
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
It CAN be fixed.
Chances are very high that the frame is toast.
Look at this thread to see what you are up against and what a motivated owner can do in a short time.
This guy is super motivated and has a strong work ethic, typically these projects move slower.
http://www.airforums.com/forums/f36/millertimes-rear-bathroom-rot-76-tradewind-thread-118881.html
Old 10-10-2014, 12:39 AM   #16
Rolland's Avatar
1967 30' Sovereign
Chiefland , Florida
Originally Posted by Basilou View Post
Rolland that was not the rear bath however, I checked underneath the body and there was no apparent rust so I don't think there was a leak. The rust is only on the frame.... That I can see
Any of them can be repaired-My 67 was basically scrap when I started, but after finishing it last month I just put 4000 miles on it going to the balloon fest in NM and back to Florida. If you need advice on anything feel free to ask, I have done several Airstreams, the one before this 67 was a 69. In order to inspect the frame you need to pull the belly pan- This is a big job, but a good idea on these because even if the frame is OK you will probably have to replace the loose, corroded, and missing rivets anyway. Then you can re-insulate the floor, paint the frame, string new wiring, run new gas lines, install a grey water tank if it doesn't already have one, inspect the black water tank, etc. The two worst places on the frame are usually just behind the rear axle, and where the hitch and frame meet, so look underneath first. Good luck! Rolland 5953
Rolland is offline   Reply With Quote
sovereign
How can I get an Airstream inspected before I purchase? anniemaine Buyer Guidelines 6 09-05-2013 01:05 PM
Need advice before buying a Sovereign with water damage emanboulay Trailer Values 17 03-14-2012 01:48 PM
1969 Sovereign :: 1969 Airstream Sovereign evers310 Airstream Registry Discussions 0 08-19-2011 08:31 AM
First Airstream purchase... need purchase tips, please. movin-in Buyer Guidelines 8 06-03-2010 05:09 PM
Possible purchase need purchase/deposit/title forms LiLNomad Dollars & Cents 5 05-28-2010 12:59 PM
