Old 02-06-2013, 04:48 PM   #1
Airstreamer NW
2010 25' FB Flying Cloud
Fall City , Washington
How to work on the top of an airstream
I need to perform routine cleaning & maint. of my fantastic fan on our 2010 25' FC. Including replacing the plunger switch.
How can I best access the top either by bridging it or sheating it or what? I've obviously cleaned the top from the side on a ladder but never been on top of my airstream.
I would appreciate experienced advise on this.
Lou
Red Hound is offline   Reply With Quote
Old 02-06-2013, 04:58 PM   #2
RUMSHIP's Avatar
1988 32' Excella
Bonita , California
Images: 16
Lean a ladder on the awning spool and walk on the rivet line.
Happiness only real when shared.
Christopher Johnson McCandless
2/12/68 - 8/18/92
RUMSHIP is offline   Reply With Quote
Old 02-06-2013, 05:00 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I have a big block of foam that came as packing in something long ago. I lay that on the side of the trailer. I have a Little Giant ladder which I then rest on the foam block. I extend the ladder well above the height of the trailer so that I can just step off of the ladder on to the trailer. Stay on the ribs which are under the rivet lines. You can tell instantly if you put your weight down and it is not on a rib. Be careful, especially coming down.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 02-06-2013, 05:04 PM   #4
Protohyp's Avatar
1977 31' Excella 500
Los angeles , California
Send a message via AIM to Protohyp
MAKE absolutely sure someone knows you're up there. It can be very slippery and if you take a tumble it could be disastrous.
Protohyp is offline   Reply With Quote
Old 02-06-2013, 05:25 PM   #5
btowntincan's Avatar
Mercer Island , Washington
Yes, bring a phone in case the ladder slips!
btowntincan is offline   Reply With Quote
Old 02-06-2013, 05:56 PM   #6
Olie's Avatar
2004 30' Classic
Beaumont , Texas
I've washed the roof by walking thr rivet line. Very slippery. Other maint. required placing a piece of plywood accross the rivet line and working off it. The roof still soundes like you are crushing a beer can. After removing the plywood the roof looked normal.
Olie is offline   Reply With Quote
Old 02-06-2013, 07:30 PM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
Lou
1) The only truly soft areas are the front and rear end cap; stay off them.
2) You get up to the top by leaning a ladder against the side with suitable padding where the ladder contacts the shell. I use old towels held in place on the ladder with electrical tape. Be sure the ladder extends at least 3 rungs over the roof so you can hold onto it to keep your balance.
3) Once you're on the roof, you can step anywhere there's a rivet.
4) Safety is a major concern, use the buddy system, be sure of the ladder and the stability of the ground it contacts.
Old 02-06-2013, 07:54 PM   #8
dznf0g's Avatar
Oswego , Illinois
I us a combination of everything Jammer said AND I have Olie's piece of plywood (actually 2 of them) which are large enough to span 2 ribs plus a bout 8". I use the wood for sitting and kneeling.
Also, it is worth buying good deck shoes, made for slick boat decks. The "stickier" the better.
-Rich-
Old 02-06-2013, 11:21 PM   #9
Airstreamer NW
Accessing the roof
You've all got more courage than I have. I can just see my #10 shoe putting a big dent in one of the panels.
I appreciate all your advice and will use a padded ladder on the awning roller and padded plywood on top.
thanks a lot for the help.
Lou
Old 02-06-2013, 11:38 PM   #10
Hodum's Avatar
1995 34' Excella
Corinth , Mississippi
At 6'-4" and 285 lbs. I am not getting on the top of mine.
Why settle for anything less?
1995 34ft Classic Excella 1000
2012 Kings Ranch F-250 FX-4, 6.7 diesel, 6 speed auto trans.
TAC # MS-8
Hodum is offline   Reply With Quote
Old 02-07-2013, 01:08 AM   #11
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Lou
Hi, I have been up there a few times. I use a mover's blanket thrown onto the top side of my trailer to cover where I plan to lean my ladder. Because of how my trailer sits in my driveway, I have to go up on the street side. I lean my ladder on the awning rail.
True story: I had to go up top to replace my Fantastic Vent plunger switch. I removed it so I could match it up with a new one. When I came down, I decided to take my ladder down too because it was based on my neighbors property. I laid my ladder down in my driveway, behind my trailer. I then went into my garage to put a tool away. Walking from my garage, and down my driveway, behind my trailer, I heard a big boom and my trailer started rocking like crazy. My first thought was that some idiot drove a truck up my driveway and hit my trailer. But in reality it was a 5.0 Earthquake. I was just on top of my trailer no longer than 5 minutes before the Earthquake hit.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 02-07-2013, 04:08 AM   #12
DougZ's Avatar
1972 27' Overlander
Venice , Florida
I replaced all 3 vents and covers and never had to actually get on the roof. I leaned the ladder against the sides and could reach over half way across the roof so I never needed to climb on it. It takes a little stretching, but it's worth it to not damage the rivets.
TAC FL-1
W4JDZ
DougZ is offline   Reply With Quote
Old 02-07-2013, 05:28 AM   #13
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
I use three or four 1 x 6 pine boards about 5' long depending on where I need to access. I run them parallel to the awning on the curbside and the awning acts as a stop to keep them from sliding off. They are long enough to span two to three ribs that way and their width allows for better distribution of the weight to the curvature of the top of the trailer. I do my best to not go up there but sometimes it is necessary.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 02-07-2013, 07:43 AM   #14
dznf0g's Avatar
Oswego , Illinois
Eventually....someday....when I retire and get my place with a barn, I will buy some scaffolding, spend some time modifying it for all rooftop activity. Or, if I build, I may put in a "lowered ceiling" area kind of like the A/C, vent, skylight, etc. install area at JC.
-Rich-
