02-06-2013, 04:48 PM
2010 25' FB Flying Cloud
Fall City
How to work on the top of an airstream
I need to perform routine cleaning & maint. of my fantastic fan on our 2010 25' FC. Including replacing the plunger switch.
How can I best access the top either by bridging it or sheating it or what? I've obviously cleaned the top from the side on a ladder but never been on top of my airstream.
I would appreciate experienced advise on this.
Lou
02-06-2013, 04:58 PM
1988 32' Excella
Bonita
Lean a ladder on the awning spool and walk on the rivet line.
Happiness only real when shared.
Christopher Johnson McCandless
2/12/68 - 8/18/92
02-06-2013, 05:00 PM
1968 24' Tradewind
Oxford,
, Mississippi
I have a big block of foam that came as packing in something long ago. I lay that on the side of the trailer. I have a Little Giant ladder which I then rest on the foam block. I extend the ladder well above the height of the trailer so that I can just step off of the ladder on to the trailer. Stay on the ribs which are under the rivet lines. You can tell instantly if you put your weight down and it is not on a rib. Be careful, especially coming down.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
02-06-2013, 05:04 PM
1977 31' Excella 500
Los angeles
MAKE absolutely sure someone knows you're up there. It can be very slippery and if you take a tumble it could be disastrous.
02-06-2013, 05:25 PM
Mercer Island
Yes, bring a phone in case the ladder slips!
02-06-2013, 05:56 PM
2003 30' Classic
Las Cruces
, New Mexico
I've washed the roof by walking thr rivet line. Very slippery. Other maint. required placing a piece of plywood accross the rivet line and working off it. The roof still soundes like you are crushing a beer can. After removing the plywood the roof looked normal.
02-06-2013, 07:30 PM
Wise Elder
2010 30' Classic
South of the river
Lou
1) The only truly soft areas are the front and rear end cap; stay off them.
2) You get up to the top by leaning a ladder against the side with suitable padding where the ladder contacts the shell. I use old towels held in place on the ladder with electrical tape. Be sure the ladder extends at least 3 rungs over the roof so you can hold onto it to keep your balance.
3) Once you're on the roof, you can step anywhere there's a rivet.
4) Safety is a major concern, use the buddy system, be sure of the ladder and the stability of the ground it contacts.
02-06-2013, 07:54 PM
Oswego
I us a combination of everything Jammer said AND I have Olie's piece of plywood (actually 2 of them) which are large enough to span 2 ribs plus a bout 8". I use the wood for sitting and kneeling.
Also, it is worth buying good deck shoes, made for slick boat decks. The "stickier" the better.
-Rich-
02-06-2013, 11:21 PM
Fall City
Accessing the roof
You've all got more courage than I have. I can just see my #10 shoe putting a big dent in one of the panels.
I appreciate all your advice and will use a padded ladder on the awning roller and padded plywood on top.
thanks a lot for the help.
Lou
02-06-2013, 11:38 PM
1995 34' Excella
Corinth
, Mississippi
At 6'-4" and 285 lbs. I am not getting on the top of mine.
Why settle for anything less?
1995 34ft Classic Excella 1000
2012 Kings Ranch F-250 FX-4, 6.7 diesel, 6 speed auto trans.
TAC # MS-8
02-07-2013, 01:08 AM
Salem
, Oregon
Lou
Hi, I have been up there a few times. I use a mover's blanket thrown onto the top side of my trailer to cover where I plan to lean my ladder. Because of how my trailer sits in my driveway, I have to go up on the street side. I lean my ladder on the awning rail.
True story: I had to go up top to replace my Fantastic Vent plunger switch. I removed it so I could match it up with a new one. When I came down, I decided to take my ladder down too because it was based on my neighbors property. I laid my ladder down in my driveway, behind my trailer. I then went into my garage to put a tool away. Walking from my garage, and down my driveway, behind my trailer, I heard a big boom and my trailer started rocking like crazy. My first thought was that some idiot drove a truck up my driveway and hit my trailer. But in reality it was a 5.0 Earthquake. I was just on top of my trailer no longer than 5 minutes before the Earthquake hit.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
02-07-2013, 04:08 AM
1972 27' Overlander
Venice
I replaced all 3 vents and covers and never had to actually get on the roof. I leaned the ladder against the sides and could reach over half way across the roof so I never needed to climb on it. It takes a little stretching, but it's worth it to not damage the rivets.
TAC FL-1
W4JDZ
02-07-2013, 05:28 AM
2010 28' Flying Cloud
Lower Alabama
, USA
I use three or four 1 x 6 pine boards about 5' long depending on where I need to access. I run them parallel to the awning on the curbside and the awning acts as a stop to keep them from sliding off. They are long enough to span two to three ribs that way and their width allows for better distribution of the weight to the curvature of the top of the trailer. I do my best to not go up there but sometimes it is necessary.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
02-07-2013, 07:43 AM
Oswego
Eventually....someday....when I retire and get my place with a barn, I will buy some scaffolding, spend some time modifying it for all rooftop activity. Or, if I build, I may put in a "lowered ceiling" area kind of like the A/C, vent, skylight, etc. install area at JC.
-Rich-
02-07-2013, 08:23 AM
1992 34' Excella
Austin
I've been all over mine (not the end caps) and by staying on the rib rivet lines I've never had a problem. I've installed two FFs and changed the a/c unit using this method.
At first I made a simple scaffold by leaning a padded ladder against each side and bridging across from ladder to ladder with a 2x12 and a rope tying the bottom of the ladders together underneath the trailer, but after working off of it for a while my back told me that something else was going to have to happen and I found that my big butt was easily supported by stepping only on the ribs. A piece of thick plywood which bridges across 3 ribs can be handy when you have to kneel for a long time.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
02-07-2013, 09:16 AM
2006 25' Safari
St. Augustine
I use a straight ladder, lean it against the door framing with a pad insulation and lift up two 4 x 2 pieces of board as work area/support platforms. They bridge across the ribs or rivet areas and it is more secure. You have to be careful as things move and slide. It has helped a lot. The roof on mine is not that solid feeling as it flexes. Perhaps that is different than the older ones but I would not get up there and move around too much without focusing on using the rib areas as support.
02-07-2013, 10:05 AM
1982 34' Limited
Harrowsmith
, Ontario
I've been able to work on mine by leaning too - that might not work with one of the newer widebody models.
02-07-2013, 10:24 AM
2007 28' International CCD
Springfield
, Missouri
I cut a 2x12 3.5 ft and covered it with carpet.When I am on the roof it spans the rivet supports and is more comfortable to work up there and easily moved.Lean the ladder on drip rail over the door.I put duct tape on the drip rail first so not to scratch it.
02-07-2013, 10:44 AM
Maniacal Engineer
Lopez Island
When I need to be on the Tin Picke's roof I wear sneakers and use an 8' step ladder to get up there. The rolled up awning is a handy way to keep from sliding down during ladder/roof transition. I stay on rivet lines as much as possible, and never go on end-caps. I'm over 200 lbs, and the roof felt fine when I installed the solar panels.
The hardest thing to do is anticipating every tool you'll want; I end up going up and down a fair bit, so using the awning has made that a lot more practical.
Working on the roof is not difficult, but it does require "being in the moment" to prevent mistakes. If you can't work on a 4:12 house roof, you prob. don't want to be on the Airstream either.
- Bart
02-07-2013, 11:25 AM
1992 34' Excella
Austin
That reminds me Bart - I have a nylon tool bag attached to a rope that I can haul up after I'm on top. I put everything in it that I might ever possibly need (including a roll of paper towels) and that saves me a lot of vertical commuting.
Crusty
Lake Travis, TX
"Rancho Deluxe"
