Old 03-20-2019, 11:18 AM   #1
Houston , Texas
How to seal seams and rivets
I have searched but have not found a comprehensive post about how to seal seams and rivets while the interior skin is off
I am also looking to see if there are any post about renovating a 48 Spartan Manor, I am thinking about buying one.
John
John_Dennis is offline   Reply With Quote
Old 03-20-2019, 02:15 PM   #2
Jeffersonville , Kentucky
Not sure a comprehensive post is needed.
Get a bunch of tubes of Trempro 635
The skins are off, so cover all seams and rivets. use a gloved finger or tool to smooth out.
I tried a different sealant from Lowes and it had a high odor, had to peel it all off and go with the Trempro.
I also covered the rib to skin seams.
http://www.airforums.com/forums/f174...ml#post2208653
Dremel is offline   Reply With Quote
Old 03-20-2019, 02:17 PM   #3
also about the 48 Spartan Manor
If you find a post here about that, it will just be luck since this is an Airstream site. But most here love all campers.
But might have better luck on Tin Can Tourist site
Old 03-20-2019, 04:51 PM   #4
Hyo Slvr's Avatar
2016 27' Flying Cloud
Greenfield , Indiana
Might try looking for Flyte Camp in Bend, OR. The Scribner's have restored a couple of them for their TV show. Reach out to them, they seem like the type of folks that will share their knowledge.
Hyo Slvr is offline   Reply With Quote
Old 03-21-2019, 11:08 PM   #5
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
The current method used to seal at the factory is Adseal on the roof and seal tape on all the panel edges. I don't think they use any sealant inside any more. Also that makes it a lot easier to replace damaged panels not having to cut around the old seal that is difficult to separate. If you need a panel on a late model trailer they dial in the VIN in their computer and the computer cutting and drilling machine manufactures it for you.
Old 03-22-2019, 10:47 AM   #6
1970 27' Overlander
New Orleans , Louisiana
vintage kin - restoration of Spartan
Have you seen this thread on a 47 Spartan?
http://www.airforums.com/forums/f417...on-166502.html
OhLook_SHINY is offline   Reply With Quote
Old 03-22-2019, 12:01 PM   #7
2019 27' Flying Cloud
Grand Rapids , MI
Have you guys ever tried this product??
https://www.3m.com/3M/en_US/company-...3241577&rt=rud
tommgr is offline   Reply With Quote
WHY seal new panel seams and rivets from outside? SGT374 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 01-28-2019 12:57 PM
Need some advise on seams Roof seams that failed Big Rich Roof 2 06-25-2018 06:41 PM
RIVETS, Rivets, and rivets Over59 Ribs, Skins & Rivets 31 10-06-2015 12:53 PM
seams and window frame seal grin61 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-04-2014 11:01 PM
Clean the edges and seal the seams... Nolavalkyrie Vintage Kin 13 09-26-2013 11:47 PM
