Old 08-14-2016, 10:53 PM   #1
Sacramento , California
Unhappy How to remove Two battery compartments
I want to remove and reinstall the two black plastic battery storage compartments and access doors, but I am having difficulty figuring out how to Remove the access door and cast aluminum frame on front of trailer. Does anyone know the procedure?
Dbright is offline   Reply With Quote
Old 08-14-2016, 11:43 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Unhappy
Unfortunately, the lip of the plastic battery compartment is sandwiched between the aluminum frame and the skin of the trailer.
You have to drill out the rivets and either replace them with new rivets or (stainless steel) screws.
Sorry.
Old 08-15-2016, 07:33 AM   #3
dznf0g's Avatar
Oswego , Illinois
The rivets and/or screws are on the inside wall. It is well worth the effort to remove the couch and any other interfering items before attempting.
-Rich-
Old 08-15-2016, 08:35 AM   #4
2000 30' Excella
Atlantic Beach , Florida
Battery Boxes
I am a new owner and I am redoing a 2000 30' Excell The batteries are under the couch and are very difficult to remove on the outside. Any suggestions about how to replace or modify the battery boxes and avoid the Gas leaking into the coach
Mike49Mitzie is offline   Reply With Quote
Old 08-15-2016, 10:26 PM   #5
aircraft1's Avatar
1977 27' Overlander
Winnetka , California
You have to drill the rivets from he outside and the boxes come out with the door case. You can either re install the new ones with Olympic rivets and or screws. If you opt for screws that you will have to access the inside to install nuts. I just did my boxes and it's not hard to do.
aircraft1 is offline   Reply With Quote
Old 08-16-2016, 05:58 AM   #6
dznf0g's Avatar
Oswego , Illinois
I think this depends on the Era of trailer. Mine has no rivets on the outside. It is all sandwiched with fasteners on the inside.
-Rich-
Old 08-16-2016, 02:27 PM   #7
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I had this work done at JC . . . the battery boxes and access doors were removed; two size 4D AGM batteries were installed on stainless steel trays; trays were screwed right into the A-frame; the batteries were secured using no-name battery box straps; the exterior panel (the "plate") was replaced, so that there are no access doors; between the batteries is my Xantrex FS3012 3Kw pure sine wave inverter/charger/converter. A piece of plywood is fitted over the top (not shown) to prevent any possibility of the battery terminals shorting out if the straps break and the batteries bounce up to the gaucho springs.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Battery size for 77 Airstream front compartments squrlgurl 1977 Excella 500 14 07-23-2016 11:14 AM
Adding battery compartments and doors Jammer Batteries, Univolts, Converters & Inverters 3 12-02-2010 03:48 PM
Locked out of our exterior compartments...no keys Anna Exterior Storage Compartments & Access Doors 12 07-07-2008 10:20 PM
check engine compartments for "tenants" maznblu Tow Vehicles 0 12-01-2003 11:05 AM
Battery weeping outa the compartments Kistler Our Community 4 06-16-2003 08:39 PM
