Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 06-01-2019, 03:01 PM   #1
2016 28' International
Alabaster , Alabama
How to remove rear A/C from ducted international
Help! Does anyone know how the Dometic Penguin II's are attached to a ducted International Serenity and how to remove it? Our 2016 rear unit won't cool or heat and after doing all the checkouts and reading other posts, we bit the bullet and bought a new unit to replace the defective one (6 months past warranty). Plan to replace myself, but at a bit of a loss as to how it is attached. Thanks for any help!
gmattingly is offline   Reply With Quote
Old 06-01-2019, 09:32 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
It is easy to remove. On your ducted system remove both air intakes. The AC is held/clamped in place with 4 long bolts that go through a cast meter bracket inside the trailer and into the metal frame on the AC unit.
Here’s a pic of mine that is not ducted. Yours will have to be removed from inside through the air intake.
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 06-01-2019, 10:57 PM   #3
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
There should be a compressed foam gasket between the ac and your rooftop. I don't think the manufacturers recommend caulk or seal, but my Airstream class b ac was installed with caulk.
If no caulk, the gasket could still be stuck from compression. So it may not lift free after the bolts are removed. It's going to be up to your how to get the ac pushed up and freed so it can be removed.
I replaced my ac with a unit by the same manufacturer (newer model) and it was basically plug & play. Youtube was very helpful.
Good luck.
rowiebowie is offline   Reply With Quote
Old 06-03-2019, 10:35 AM   #4
Alabaster , Alabama
Smile
Thanks all. Got the unit replaced, used the drip cups from the unit I was replacing, all was pretty straight forward. Hindsight being 20/20, would probably have ordered an additional gasket kit and put it on, as the cups can press into the roof if you torque bolts to the recommended 50" #'s. The factory installed unit wasn't torqued down that much and it didn't use an additional gasket. We've got cool air again in the rear!
Post 2015 International owners, are you happy with the new ducted A/C system? DaytonaDan 2011 - 2015 International 18 07-30-2016 11:19 AM
Ducted A/C in International Series DaytonaDan Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-26-2016 09:23 PM
Non ducted VS Ducted ianburnett Furnaces, Heaters, Fireplaces & Air Conditioning 3 12-01-2012 11:24 AM
Ducted or Non-Ducted A/C tesstoaster Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-22-2012 01:43 PM
74' Excella, to remove wiring or not to remove? BaltiHimal Electrical - Systems, Generators, Batteries & Solar 3 05-30-2010 10:23 AM
