I would dearly appreciate instructions/pics on the best way to remove and re-install this trim. I need to reseal what the AS dealer never did. Thanks ahead of time!
The trim on our 2012 is easily removed from the channel. Simply use a flat blade screwdriver to start one end and lift the chrome plastic strip away. You will have to replace the trim as it is destroyed in removal. After the trim is out you will see the screws that hold the channel to the body of the Airstream.
