Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 01-10-2016, 09:50 PM   #1
2014 25' Flying Cloud
los gatos , California
How to remove belt line, trim.
I would dearly appreciate instructions/pics on the best way to remove and re-install this trim. I need to reseal what the AS dealer never did. Thanks ahead of time!
smr95032 is offline   Reply With Quote
Old 01-11-2016, 03:21 AM   #2
Bruce B's Avatar
2021 25' Globetrotter
Jamestown , Rhode Island
The trim on our 2012 is easily removed from the channel. Simply use a flat blade screwdriver to start one end and lift the chrome plastic strip away. You will have to replace the trim as it is destroyed in removal. After the trim is out you will see the screws that hold the channel to the body of the Airstream.
Bruce B is offline   Reply With Quote
Sealing belt-line trim? Friday Clearcoat, Exterior Paint & Trim 11 09-15-2020 05:13 PM
I need a piece of belt-line trim... malconium Clearcoat, Exterior Paint & Trim 14 09-28-2017 11:01 AM
Belt Line Trim Removal Advice urban71 Ribs, Skins & Rivets 3 10-27-2010 04:21 PM
Belt Line Trim Needed For 1956 F.C Dan Clayton Clearcoat, Exterior Paint & Trim 2 08-04-2006 09:47 PM
