I agree with az-streamer. I'm an old furniture guy. I like elmers wood glue for this kind of stuff. I'd get me a thin blade putty knife, some rags, maybe a couple toothpicks, and glue.
I always make sure to smear the glue in under the laminate real good, but not use too much, because it'll squeeze out when you push the laminate, trim, or whatever you got down.
Wipe everything real good after squeezing out the excess, then tape it tight if you can, like az-streamer said.
Use clamps and/or clamp boards if possible, and if a flat surface, placing weight on top to hold things down.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
