Old 01-11-2016, 06:56 PM   #1
2013 27' FB International
olney , Illinois
How to mount an extra sewer hose pipe?
got a sewer hose pipe from Valera ... for my extra 10 feet of sewer hose
now....
do I just use 4 metal screws and screw it into the underbelly ?
I am afraid that I find something important and than have a mess drilling into it
any ideas ?
Thanks Thor
2013 International 27 FB, 2010 Tundra, Centramatics, Tpi, Equalizer hitch. Selling folding bikes under ThorUSA.com and if I am not working or Airstreaming I love to sail
thorusa is offline   Reply With Quote
Old 01-11-2016, 08:31 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
That's how I would do it. Just steer clear of the holding tanks.
CRH is offline   Reply With Quote
Old 01-11-2016, 10:29 PM   #3
waltb's Avatar
2014 25' Flying Cloud
San Luis Obispo , California
Send a message via AIM to waltb Send a message via Skype™ to waltb
That's what I did, works fine.
2014 Flying Cloud - 25' RB
2016 Tundra
Air# 42643; WBCCI# 3884
waltb is offline   Reply With Quote
Old 01-16-2016, 09:37 AM   #4
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
My storage pipe is attached into the frame on one end and to the belly pan on other end. Used three 3/16" pop rivets on each side of tube into belly pan. Used #12 metal screws into frame. Time to rehang it, been nearly ten years.
Dreamstreamr
2005 International CCD 25SS
Http://Dreamstreamr.com
Living the Dream
Jim Cocke,
International President
WBCCI Wally Byam Airstream Club
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
Old 01-17-2016, 10:06 AM   #5
Amsterdamer's Avatar
2015 27' Flying Cloud
Caledonia , Michigan
I also added a second hose holder. It came as a two part expandable unit. The center was not supported and eventually sagged, as the only connection points to the trailer were at the two outer ends. Adding an aluminum center support strap at the expansion point in the middle fixed the issue.
Amsterdamer is offline   Reply With Quote
Old 01-18-2016, 07:35 AM   #6
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
My sewer hose storage pipe is about half way between the tongue and wheels- about under the living room/dining room- no holding tanks there-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 01-18-2016, 07:55 AM   #7
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Just a heads up. On my previous trailer the po used small rivets to attach his storage pipe. First time I pulled into a highway gas station I bottomed out and ripped the pipe off. It hung in there until I got on the highway and flew off at speed. Luckily no additional damage was done to the trailer and more importantly no other vehicles made contract with it. The pipe on my current Safari is attached with robust screws and rivets. It would take a solid hit to rip it off.
MICHAEL
Old 01-18-2016, 08:10 AM   #8
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
If you feel around under the belly pan, and/or look for screws/rivets, you may find a transverse support you can screw into. Another alternative is if there is a seam in the belly pan it will be stronger than just the single thickness of pan. Mine was originally attached to just the belly pan and had been re-attached with larger and larger screws but was about to strip out. I rebuilt some larger pipes out of 5" PVC fence post covers to fit my new hoses with larger flanges and made 1/8" aluminum straps which I was able to attach to framing members for one holder and the other was mounted under the screws holding the straps around the tanks.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 01-18-2016, 08:21 AM   #9
Wayne&Sam's Avatar
Cuddebackville , New York
Images: 21
I also bought an extension sewer hose. It fit in the same carrier tube as the regular hose. It is a bit of a stretch to open the far end of the tube, but I've only needed the extension a couple of times.
2012 Dodge Durango Hemi/AWD
Old 01-18-2016, 01:07 PM   #10
Gainesville , Florida
This would make your AS cosmetically challenged, but i have seen the tubes mounted vertically on truck campers, etc.
Old 01-18-2016, 02:42 PM   #11
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
We use the EZ Coupler hose kit. Two hoses, connected together, fit in the stock storage tube on our 22 FB Sport. You just have to compress them in very snugly. I do not envision needing more than 20' of sewer hose to hook up.
Cannonball is offline   Reply With Quote
Old 01-18-2016, 03:58 PM   #12
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
PVC pipe - drilled and threaded a frame crossmember and installed three hangars..I wouldn't trust sheetmetal screws into the belly pan
No WD, but a great DW!
robert claus is offline   Reply With Quote
Old 01-18-2016, 06:08 PM   #13
2008 30' Classic
Orland Park , Illinois
Hangers
Clause,
Where did you find those large hangers for the large pvc?
I like that idea, drilling and tapping!
flyerboy is offline   Reply With Quote
Old 01-18-2016, 08:02 PM   #14
2000 19' Bambi
I found them at Addison Building Supply in Mount Prospect, but I think they were old stock. You should be able to find something similar at any home supply, if they don't have these.
How can I repair or replace sewer hose storage pipe? Acker997 Waste Systems, Tanks & Totes 10 06-27-2010 01:17 PM
Sewer vent pipe cover gaskets Inland RV Center, In Leaks - Weatherstrips, Gaskets, Caulks & Sealants 43 06-10-2009 09:04 PM
What is extra hose inside Thetford Aqua Magic Julian H Sinks, Showers & Toilets 0 04-20-2009 08:44 PM
Extra, Extra!! codybear Airstream "In the News" 3 04-16-2007 03:59 PM
Extra hose on toilet Safari Tim Sinks, Showers & Toilets 18 07-02-2006 12:00 AM
