Old 08-07-2016, 05:15 PM   #1
2006 16' Safari
San Francisco , California
How to maintain beautiful hardwood floor
New to us 2006, Bambi 16' Quick Silver Special Anniversary model. Appears to have had no use. The floor is multi-stripe hardwood not the normal AS flooring. The wood is untreated and beautiful but I'm afraid anything spilled on it will seep into the wood and stain it.
Should I be worried?
If we should we seal it, what with?
Thanks!
New to land cruising! New to retirement! YUM!!!
SagaCapt is offline   Reply With Quote
Old 08-07-2016, 07:11 PM   #2
Missouri Valley , Iowa
Is it "engineered" (fancy word for fancy plywood)? Untreated would be very unusual. What did previous owners tell you about it? Several coats of urethane would go a long ways toward protection. If it's untreated, spills will be a big concern!
Dan
Farmer Dan is offline   Reply With Quote
Old 08-07-2016, 07:51 PM   #3
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Yes, you need to be very careful!
Actually I now prefer a sheet flooring as we have i our AS, especally in the galley area.
Our last trailer - an SOB - have a beautiful hardwood floor in the galley area that teh previous owner had recently installed before we bought it, but within a couple of years it looked really bad.
We tried to look after it but it seemed that water splashed from activities around the sink got down into the joints and caused blackening - due to mould I suppose.
Nothing we could do short of removing the flooring. We sold it that way.
Had we kept it we would have had to remove the wood and replace with something impervious to water. That is what the people who bought it from us did.
Hopefully you have better luck than we did and no doubt you can if you take more care than we did!
Maybe there is a way to seal it so this cannot happen - perhaps if you are fortunate t does have some sort of sealer on it.
Worth trying to find out.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 08-08-2016, 11:20 AM   #4
2006 16' Safari
Hey Dan,
Not plywood. Beautiful laid in planking!
I'm thinking urethane as well.
Old 08-08-2016, 12:06 PM   #5
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
I recommend the following sequence/products to get the best looking and durable finish over the long term.
First, sand the surface with 180 grit and remove all dust (vacuum & tack cloth). Lightly wet/dampen the surface with a cloth and let dry. Lightly sand with 220 to eliminate the nibs that appear.
Apply sealer (a wax-free clear/blonde shellac) to retain original coloring. Two coats should be enough with a 220 grit sanding after application. Use a tack cloth between (all) applications after sanding to minimize dust particles appearing.
The final coats should be a water-based urethane formulated for flooring (light sanding between coats). The 'floor' formulas have more solids than regular polyurethane and cure to a harder finish to endure traffic.
Stay off the finish for at least five days so it has the opportunity to cure and harden sufficiently to resist marking.
Sirs Gawain & Galahad
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 08-08-2016, 03:55 PM   #6
SagaCapt, you should be in sales of some sort ---- if you aren't already!! You got them fancy words going for YOU!!
Dan
Old 08-08-2016, 04:39 PM   #7
2006 16' Safari
Dan, LOL, yes many years ago (1970's) I was a salesmen.
Then I found more money and much more job security in engineering and programming.
That said, sweet talking is an efficient way to gets get things done sometimes.
Old 08-09-2016, 03:17 AM   #8
2017 23' Flying Cloud
2016 Interstate Lounge Ext
New England , Ontario
Sparkling Floor
Throw rugs at doorway would spare you debris from scartching your floor off the shine. Do not wet mop or steam mop a wood floor which would dull the finish and take the sheen away. wipe off spills with dampened cloth. Daily sweep or dust mop. Weekly vacuum using bare floor setting,use cleaner recommended monthly.
EdwardCharet is offline   Reply With Quote
Old 08-09-2016, 12:55 PM   #9
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
If it is raw wood for sure, I am going to be a dissenting voice for urethane. It can be a very durable floor but it will scratch and it is a bear to repair. Often requiring complete resand down to bare wood. I am a furniture maker and have a hickory floor in my home that I T&G'ed and installed with 3,000 square pegs myself. I finished it with Waterlox, originally developed for wood floors. It will also eventually scratch but can be repaired in munites without sanding off. I use this finish on anything that I care about. Easy to apply, easy to repair, and very durable. https://www.waterlox.com/products-it...er-finish.aspx
Royce (K0RKK) 146.460 simplex
Web page http://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 08-09-2016, 03:45 PM   #10
80Ram's Avatar
2017 25' Flying Cloud
Scott City , Missouri
If you use urethane on your floors I would stay away from floor polishes. I would use Bona Floor Cleaner NOT Bona High Gloss Floor Polish.
80Ram is offline   Reply With Quote
Old 08-09-2016, 06:44 PM   #11
2003 31' Classic
Terra Alta , West Virginia
I would use the Bona sealer and finish. Amazing stuff. Used it in my house. Was recommended by a friend who does this for a living. No odor either. Follow the sanding and application instructions. You will be pleased with the Bona products...I was. I got mine on line too.
Dave
wvstreamer is offline   Reply With Quote
Old 08-09-2016, 10:10 PM   #12
2006 16' Safari
Royce, WVStreamer,
Wow, both Bona and Waterlox look great. I'm concerned that the drying requirement for lots of ventilation by Waterlox may be tough.
I'm really thankful to everyone for the input!
Old 08-10-2016, 08:35 AM   #13
Silver Star
rucos's Avatar
1970 23' Safari
Victoria , British Columbia
when I rebuilt mine I told my wife she could do any floor as long as it was light and "bullet proof" ....we installed Vinyl plank flooring and after 2 years we love it!! ....ours looks like older wood planks and people think it is wood ....rocks stuck in your shoe...water spills....dog claws ...no problem!!
rucos is offline   Reply With Quote
Old 08-10-2016, 09:18 AM   #14
Long Island , New York
If you decide to go with poly, be sure to use the "Traffic Grade" version, as it will stand up to sand etc. much better. Higher unit cost, but tough stuff . . . !
How to properly maintain hickory cabinets m.hony Upholstery, Blinds, Walls & Interior Finishes 6 12-27-2013 05:12 PM
Clearcoat to Maintain Appearance?? Help! big_john Clearcoat, Exterior Paint & Trim 0 05-30-2011 10:53 AM
Is AS MH difficult/expensive to maintain/repair? aaastircrazy Mechanics Corner - Engines, Transmission & More... 6 09-04-2009 08:09 AM
How should I clean & maintain the exterior AccessMaster Cleaning, Stripping & Polishing 11 11-14-2005 06:20 PM
