Old 08-10-2016, 11:05 AM   #15
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
Originally Posted by SagaCapt View Post
Royce, WVStreamer,
Wow, both Bona and Waterlox look great. I'm concerned that the drying requirement for lots of ventilation by Waterlox may be tough.
I'm really thankful to everyone for the input!
Windows open, drying Waterlox should not be a problem. Here in Colorado, one coat a day for 3-4 coats depending on wood species. Walk in socks by day two after final coat and full cure in 7 days. UV light will hasten the cure. If you have a lot of humidity it can take a day or two longer.
Oops! I see you are in CA. Sadly original Waterlox may not be VOC compliant if you live in CA. So a special Waterlox has been created just for your use. The formula has been changed and I cannot recommend the CA version.
Best is to leave CA, too may things cause cancer in CA. :-)
Royce (K0RKK) 146.460 simplex
Web page http://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
How to properly maintain hickory cabinets m.hony Upholstery, Blinds, Walls & Interior Finishes 6 12-27-2013 05:12 PM
Clearcoat to Maintain Appearance?? Help! big_john Clearcoat, Exterior Paint & Trim 0 05-30-2011 10:53 AM
Is AS MH difficult/expensive to maintain/repair? aaastircrazy Mechanics Corner - Engines, Transmission & More... 6 09-04-2009 08:09 AM
How should I clean & maintain the exterior AccessMaster Cleaning, Stripping & Polishing 11 11-14-2005 06:20 PM
