Old 02-23-2014, 02:52 PM   #1
1992 25' Excella
WILMINGTON , Delaware
How To Get Rid Of Mold
I have a 25', 1992 Airstream Trailer with a smell we think is from mold. The smell seems to come from below the sink area in the kitchen and bathroom. The smell is worse when it is damp. Any suggestions for this problem or how to eliminate mold and the smell. Also we have a parrot that travels with us so any suggestion should be "parrot safe" Thanks for your help. LCP
LCP1963 is offline   Reply With Quote
Old 02-23-2014, 03:07 PM   #2
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
You need to find the leak, it could be the floor rotting below. Check rotten floor repair threads here to see what to do. If the smell is diredctly from the drains...clean your grey water tank. Use bleach and water solution, or a commercial tank cleaner.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 02-24-2014, 12:27 AM   #3
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Look under the kitchen sink and you may see a vacuum vented stack that assist the flow from the drain. The vent is easily removed and replaced with one from Lowes or a hardware store. When you mount the new vent, to ensure that to odour from your holding tank doesn't permeate, make sure that the threads are either covered with teflon tape or they have been liberally smeared with Vaseline (I used Vaseline on mine).
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 02-24-2014, 01:30 PM   #4
flygrrl
flygrrl's Avatar
1962 19' Globetrotter
Winchester , Ontario
smell
You could have just a plain old blocked vent stack if you have one, (leaves, pine needles, dead bird/squirrel etc. etc.) as well. If you see actual mold, remove with baking soda and water, bleach does not actually do much for mold.
But... it could be your floor from a leak or critter pee from stowaways.
Leonie
TV: 2007 Jeep GC Laredo diesel
Toy: 1995 Jeep YJ
Experience is what you get from not having it when you needed it.
flygrrl is offline   Reply With Quote
What to use for mold removal & prevention mrsfixit General Interior Topics 15 06-05-2012 06:13 AM
Trim Mold Bk Yd Safari Clearcoat, Exterior Paint & Trim 3 12-03-2011 04:41 PM
Day/night shades on classic 2008 mold chaimemet Upholstery, Blinds, Walls & Interior Finishes 3 07-21-2011 11:04 AM
Asthma, Air quality, Mold issues sweetsilver Interior Restoration Forum 3 05-10-2011 07:45 PM
