Old 10-24-2015, 06:57 PM   #1
1972 31' Sovereign
1972 25' Tradewind
northport , Michigan
How to eliminate mice
I have been battling mice for years. Started when we left our A/S at friends for the summer. I've sealed everything except for the slot for the entry step. What could I do there? I've used D-con pellet bait, sticky bait trays, dryer sheets (for deterant) etc. I've gotten/killed mice; but not all of them.
cummins is offline   Reply With Quote
Old 10-24-2015, 07:09 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
If you're not using the trailer, you don't need the step, so duct-tape over the slot. Duct tape is not mouse-proof, but at least you will have an immediate indication if any get in that way because they'll have to chew a hole through it to get in.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-24-2015, 07:10 PM   #3
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Never had a problem myself, but a farmer friend up north claims moth balls do the trick for his Motorhome stored in a barn over the winter.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 10-24-2015, 07:20 PM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I've been using these repellers for several years.
Victor PestChaser Sonic Rodent Repellent-M690S - The Home Depot
Since I started using them I have not seen any "evidence". None! I park/store my 25' trailer less than 20 feet from the woods all winter in NC.
I'm vigilant about removing all food, spices, soaps, etc. I vacuum crumbs and wipe spills. If there is anything a mouse or bug can eat I remove it when I'm not using the trailer.
I do not heat my stored trailer during cold weather. I winterize. Don't want to offer a warm bed.
I have a problem with lizards, while in FL during winter. I found some eggs in the AC when I removed the shroud.
Alan
Old 10-24-2015, 07:23 PM   #5
SteveH's Avatar
Common Sense , Texas
Since I started using them I have not seen any "evidence". None! I park/store my trailer less than 20 feet from the woods all winter.
I do not heat my trailer during cold weather. I winterize. Don't want to offer a warm bed.
Yep, I use the ones from Tractor Supply, and no mice.
Before I got these, I learned the best bait in the trap is a piece of pecan.
Regards,
Steve
Old 10-24-2015, 07:39 PM   #6
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We keep the trailer very close to a big grain field, mice are plentiful, but never had them in our Airstreams. I've thought baited traps and poison attract them so don't use it. No dryer sheets, moth balls, scented anything.
We do clean the kitchen equipment well and leave no food whatsoever in the Airstream between trips. We also hit the road for southern states in late fall when they start to look for indoor shelter. Probably both responsible for no mice during the seven years we have been Airstreaming.
Doug and Cheryl
Old 10-24-2015, 07:46 PM   #7
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Mice love Airstreams just like people do. They appreciate a well designed, high quality luxury travel trailer.
The entry areas I plugged include propane lines, rear bumper storage lid, wheel wells, fresh water drain line, belly pan seam separations, and the like. One thing I overlooked with the dog gone A frame rails where they come together under the coupler. There stands two big 6 by 2 open ended steel channels. All I needed is a mice welcome mat. This is also a good place for rain water entrance while towing.
Sonic repellants are the way to go. At least until mice get ear plugs.
David
Old 10-24-2015, 08:49 PM   #8
dkottum's Avatar
We struggle with them in sheds on our property. I think they can adapt to almost anything, except a hungry cat. They don't like cats.
Doug and Cheryl
Old 10-24-2015, 09:03 PM   #9
CRH
1995 25' Excella
xxxxx , xxxxxx
I used to get mice in my attic in the fall. I would set traps in the attic until they were none. Then, I started putting poison bait blocks in short pieces of pipe around my property. My mouse problem went away. I have never had them in my shed, garages campers, or boat.
If I had a big mouse problem, I would use a bucket trap. You can find plenty of info about them on the web.
CRH is offline   Reply With Quote
Old 10-24-2015, 09:16 PM   #10
dkottum's Avatar
CRH, you might have something there. I suspect poison bait inside brings them in, but nail them at the outside perimeter. I suppose the pipes keep birds and pets from getting to it?
Doug and Cheryl
Old 10-24-2015, 09:25 PM   #11
CRH
1995 25' Excella
xxxxx , xxxxxx
Yes, the pipes are to protect other animals from the poison.
Old 10-25-2015, 11:36 AM   #12
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Just a heads up. If you don't have power available at your trailer storage location and decide to use one of the battery power units, make sure you place it on a dish. I placed one on the floor of my 25' Safari and the AA batteries leaked and damaged the surface of the floor of the trailer.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 10-25-2015, 11:44 AM   #13
Cardinal283's Avatar
Dallas , Texas
Have you tried a cat?
Cardinal283 is offline   Reply With Quote
Old 10-25-2015, 12:13 PM   #14
texastex
Texastex's Avatar
1984 34' Excella
GARLAND , Texas
Steel wool can help.
I use steel wool, they can go into small places that they can squeeze through and cover large places. They will not eat through it. My main entry place for them was the power cord, make sure you do not put steel wool next to any terminal. otherwise it works great on the rubber cord going through the frame. I have used Decon but since I put the steel wall and suspicious places none the Decon has been eaten. It's very cost-effective also inexpensive at hardware, grocery and paint stores.
PS I replaced the steel wool every couple years.
Texastex is offline   Reply With Quote
Eliminate WD issue with water! gamana Hitches, Couplers & Balls 68 10-28-2015 07:03 PM
How do I eliminate the musty mouse smell?? mrrealtor General Interior Topics 30 04-16-2015 05:00 PM
First dog in AS - how do you eliminate that dog smell? Whirlaway The Pet Forum 42 03-22-2010 06:54 PM
Mice, Mice, Mice Jake General Interior Topics 21 12-01-2009 01:09 PM
Eliminate black water tank? macman Waste Systems, Tanks & Totes 17 07-02-2006 10:47 AM
