Old 05-13-2009, 06:04 PM   #1
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
How high to build workshop? Room to work? Need advice.
I'm getting ready to build a long planned work shop and storage building. Since I now have Aluminum Fever all previous plans are out the window and it will be designed around making our baby (unknown size but expect around 28 FT) comfortable. My lovely wife has said this building will get put up before we pull the trigger and buy our AS, so that's settled. HOA will not allow work in driveway even if it is an AS! Unbelievable!
I have an acre out back so if I had an unlimited checkbook I'd say about a 40,000 SQ FT 20 FT tall would work. I don't so I'm need to be a little creative and stick close to the original budget.
My question is has anyone built a shop and brought their AS in that might have pic's as to layout? I assume I need doors over 10 ft tall to clear the air conditioner, but how about the ceiling? Is just enough to crawl up enough?
Really appreciate everybody who shares their stories. You have already kept me from making tons of mistakes. I have studied this forum every day for a month so I can make the right choice for us. I went to look at one yesterday. The seller said after I had crawled over, under and poked just about everything that I must be some kind of inspector. I told him no thanks. Axles were great Andy,but floor in bath and back was mush and frame was rusted out. I will move on to the next one.
Thanks again everybody!
AirHeadsRus is offline   Reply With Quote
Old 05-13-2009, 07:11 PM   #2
Cantrell's Avatar
1988 34' Limited
1960 24' Tradewind
Mt. Pleasant , South Carolina
AirHead,
What a luxury to build a space to hold an Airstream you don't even own yet!! I always seem to have my cart before the horse trying to make things work.
Some things that come to mind based storing our unit. It lives under our screened porch (house is elevated as we are in coastal SC) which is 12' wide by plenty long. Height is my issue--I have to let the air out of the tires down to 10 psi to get in its spot without tearing the AC off. Refill tires when in place. Ten feet clear would be perfect for your doors if you can do it. I would also think at least 12 feet in ceiling height ---would be nice to have 2 1/2 or 3 feet for access to the top of the trailer.
30 amp dedicated outlet to plug the camper into--will allow you to run your A/C without damaging the compressor.
If you are going to have plumbing in the building, it would be nice to have a floor level sewer cleanout to be able to empty/flush your waste tanks.
Good luck on the build and in finding the right Airstream.
Bill
Cantrell is offline   Reply With Quote
Old 05-13-2009, 07:42 PM   #3
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
Yes, i agree the higher ceiling. You never know when you need to jack up the TT. Who knows, You might even come across a MH that you can't pass on.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 05-13-2009, 08:03 PM   #4
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
I've got a 12' x 12' door on my trailer garage. The 12' high is great but I would like to have 14' wide. It's surprising how small that hole looks when aiming your Airstream at it in the dark. With the 12' high door you have lots of room over top for the rollup to come in.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 05-13-2009, 08:10 PM   #5
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Good for you. I have dreams of one day being able to build an AS shop and area for storage. I drew up my concept in Google's SketchUp. The open area could be added at a later time if needed.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 05-13-2009, 09:01 PM   #6
1963 19' Globetrotter
Moline , Illinois
I'd go for the biggest doors your wallet can stand. The side of our shop that the AS is kept in has a 14' high x 12' wide door , the 16' walls give plenty of room to work on things from up above. We got the AS and then went looking for a building . The guy we bought it from is an electrical contractor who also owns an RV (SOB) , so he put in some really nice touches like floor drains, an inside dump station, and inside/outside RV power hookups.
63air is offline   Reply With Quote
Old 05-13-2009, 09:30 PM   #7
myboyburt's Avatar
1993 25' Excella
Beautiful , New Hampshire
Images: 12
We built our Airstream barn a few years ago and it's 40' deep x 30' wide. I cannot remember the height but it's wicked tall as the doors are 14' high and it has a storage loft above the bays. It was built to hold the largest Airstream MH at the time as my Parents were thinking of upgrading from their 30' Airstream MH to a bigger Airstream MH and to hold our beloved 25' Excella. It currently stores our 25' Excella and our 20' Argosy Minuet 6.0 Metre. We have plans to expand so we can store my sister's 25' Airstream and our utility trailers - this is down the road due to $$$$.
Name:	100_2390 (Medium).jpg
Michelle & Leon
New England Unit
myboyburt is offline   Reply With Quote
Old 05-14-2009, 04:52 AM   #8
Rivet Idiot
1999 34' Excella
Thanks guys, some really great ideas. I had not thought about putting a inside dump but I might as well before the slab gets done. Should be able to pre plumb and wire for what ever might come down the road.
I saw a building in a brochure (attached), similar to what Brad had drawn up. The sales guy is coming out this morning, so I'll see what the options are. I like the idea of the big over hang, covered but not enclosed.
Leon, is your barn a drive thru or do you back in. I'd like a drive thru but it adds to the expense of another door and looses bench and storage area in the back.
Thanks again for your replies,
Joe
Old 05-14-2009, 05:15 AM   #9
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
10' high doors work great for an AS, to add future resale value go with 14' high then any SOB will fit. Just as a FYI typically your sidewall height will need to be 2' higher than your door height for the clearance of a roll up door, header and associated hardware. Also consider doors that hang on an outside track and slide to the side, frees up the door opening. Electrical and plumbing are great ideas and cost less to rough in now rather than later. Otherwise you plan looks great!
Aaron
WBCCI #XXXX AIR #2495
Old 05-14-2009, 07:48 AM   #10
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Here's the proposed interior layout/floorplan. Having an interior dump connection is a great idea so I added one. The outside parking under cover would be used as a guest house or a staging spot. I can't decide about the skylights since I think they'd add to the interior heat factor.
Of course, this is all up in the air right now since it will take more $ than we can manage at the moment. Need to secure better employment for this to happen.
FF
Old 05-14-2009, 08:34 AM   #11
dstalzer's Avatar
2005 25' Classic
In 2003, before I had my Airstream, I built my garage to be able to store a 25' Airstream, my F250SD CC and a car. Due to extremely limited lot space, the garage is 28' deep by 31' wide. The RV door is 10' X 10' which is barely wide and tall enough for the newer wide body AS. If lot space was not an issue, I would have built a 40' deep by 36' wide building with a 12 X 12 door and a ceiling height of 14' just in case I decided to get anything I wanted that was larger. I insulated the garage so I never need to winterize the AS without adding any heat, even with outside temps down to 15 degrees. I do wish I had put a dump station in the driveway just outside the door.
dstalzer is offline   Reply With Quote
Old 05-14-2009, 09:05 AM   #12
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
Hi Brad,
I like your plan! I only wish I had the lot size/money to build something like this my self.
May I offer a couple of minor sugestions?
- I would include another man door back by the steps. I just feel safer if something bad happens to block you way out of the shop.
- Move the compressor as far away from where you will be working as possible. I hate compressor noise.
- Swap the toilet room and kitchen area. Although it will be difficult, it may stay a little less "sawdusty" over there
- When you have extra money, perhaps enclose the "lounge"? I guess that need really depends on how much woodworking your planning.
- Enlarge the toilet room a tad, this is a shop, not a cruise ship. (unless you really like the way airstream bathrooms feel!) Maybe add a urinal.....
- In an ideal space I would find room to store bulk supplies like 4X8 sheets and 8' lumber
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The “Ohio Airstreamer -- Informal forum for weekend camping” thread.
DanB is offline   Reply With Quote
Old 05-14-2009, 10:14 AM   #13
Rivet Idiot
1999 34' Excella
Hi all,
Just met with the sales guy for the building. After our discussion, we are thinking a 36X45,(15.9 tall on inside) without the covered 12' over hang. After looking at Brad's floor plan, it makes sense to put it back in, but will have to work into budget someway.
The doors will be sliders so will have almost the full 15 ft for clearance. All the plumbing and electrical will be easy to add in once the final size is determined. I'm basically getting a build shell that I can finish like I want on the inside. Sales guy is e-mailing me the proposal later today and I'll post the pic's if I can.
Thanks to all,
Joe
Old 05-14-2009, 10:56 AM   #14
Images: 59
Brad,
What I like most about your plan is there are two '59 Tadewinds.
I'll even be happy with the outside berth.
You should add a Penguin AC on top of mine, though.
Advice Needed on Old Airstream cboling Our Community 9 01-18-2012 01:26 PM
Fulltimer Work: Gate Guard slowmover Working on the Road 1 08-06-2011 03:12 PM
Cleaning becomes a little work becomes a lot of work - 1964 GlobeTrottin 1960 - 1964 Globetrotter 6 04-30-2011 10:36 AM
