Old 05-21-2011, 08:16 PM   #43
Splitrock's Avatar
Sioux Falls , South Dakota
I bolted mine to a 1/4" steel plate. Same with the band saw. I can move them but they won't tip over.
Old 05-21-2011, 09:41 PM   #44
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Bolt your heavy vise to a big piece of 2X12 or 3X12. You can move it to where you need to use it, or c-clamp it down to your bench when you need it there. You'll find it's seldom used inside the shop.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 05-21-2011, 09:57 PM   #45
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Great find for $10.
With a drill press - typically - most of the work is left to right of the tool. It's not very likely that you will have deep set to a project that you cannot set it up left or right. I anchored mine with 2 (two) 1/2 inch by 6 inch anchor bolts set into the slab. Just drill and pound them in - they have never given me a problem in 7 years of moderate use.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 05-22-2011, 05:35 AM   #46
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
Thanks so much for replying guys. Looks like two good options. Not sure which way I'll go. I like bolting it down and have the anchors to do it. But, I also like the option to put a plate on it so I can move it if I need to. Until I get this figured out, I may just bolt a safety chain to the drill and connect it to the wall so if it does tip it can't fall completely over. I sure do not want me or anybody else to get hurt.
Thanks again,
Joe
Annette ...... Canopener Party Planner
AirHeadsRus is offline   Reply With Quote
Advice Needed on Old Airstream cboling Our Community 9 01-18-2012 01:26 PM
Fulltimer Work: Gate Guard slowmover Working on the Road 1 08-06-2011 03:12 PM
Cleaning becomes a little work becomes a lot of work - 1964 GlobeTrottin 1960 - 1964 Globetrotter 6 04-30-2011 10:36 AM
