05-14-2009, 04:18 PM
#21
1999 23' Safari
Perrysburg
, Ann Arbor
When I built current house, basement floor had 6" pvc laid under it, penetrating up through slab in three places (Unisaw, Bandsaw/Wood Lathe, Radial Arm Saw) and then also emerging at site of remote controlled dust collector. Blast gates at each exit and Radial Arm Saw has a hose that 's removable to connect to Planer / Jointer. You can't imagine how nice woodworking can be when all the dust and chips disappear down into the floor and reemerge in a remote place into the dust collector bag. And no ducts to hang things up on or trip over ... cost was minimal, benefit was huge. Use street Ys at all connections under slab and stuff can't hang up (well, at least not so far ... it's been 12 years!).
Ryanh
05-14-2009, 04:56 PM
#22
E Pluribus Aluminus
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Land Of Enchantment
, New Mexico
Originally Posted by myboyburt
We built our Airstream barn a few years ago and it's 40' deep x 30' wide. I cannot remember the height but it's wicked tall as the doors are 14' high and it has a storage loft above the bays. It was built to hold the largest Airstream MH at the time as my Parents were thinking of upgrading from their 30' Airstream MH to a bigger Airstream MH and to hold our beloved 25' Excella. It currently stores our 25' Excella and our 20' Argosy Minuet 6.0 Metre. We have plans to expand so we can store my sister's 25' Airstream and our utility trailers - this is down the road due to $$$$.
The Argosy & Airstream sure look comfortable in y'alls barn... nice place to be in the winter I'll bet!
Jaxon
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
05-14-2009, 06:41 PM
#23
2011 34' Classic
Westchester Cty.NY
, / Miami FL
[quote=ScottW;697573
For the shop: I recommend a small attached shed for your air compressor .[/quote]
if you have neighbors close by and like working into the wee hours, this might not be ok. it sure does cut the noise inside!
Ricky
05-14-2009, 06:55 PM
#24
Ottawa
, ON
If you plan on ever polishing your AS in there, I'm going to guess that 14' would be the absolute comfort minimum.
Who wants to have to worry about banging their head on the ceiling when they polish the roof?
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
05-15-2009, 08:56 AM
#25
2011 30' Classic
Kingwood
Since you are planning space for woodworking, and assuming you have a table saw, you may want to consider identifying where it will reside and run electrical and dust collection in the concrete floor. One slick solution I saw was a channel with removable flooring, they used old raised flooring panels from computer rooms. The other solution is to run the conduit and dust collection before the concrete is poured. If you are a serious woodworker, you may want to look at 220V circuits.`
05-15-2009, 07:28 PM
#26
1993 25' Excella
Full Time
, Anywhere USA
Originally Posted by AirHeadsRus
Thanks guys, some really great ideas. I had not thought about putting a inside dump but I might as well before the slab gets done. Should be able to pre plumb and wire for what ever might come down the road.
I saw a building in a brochure (attached), similar to what Brad had drawn up. The sales guy is coming out this morning, so I'll see what the options are. I like the idea of the big over hang, covered but not enclosed.
Leon, is your barn a drive thru or do you back in. I'd like a drive thru but it adds to the expense of another door and looses bench and storage area in the back.
Thanks again for your replies,
Joe
Our barn is a back in. Our property is located on the side of a steep hill and there's a 20' drop off right behind the barn. It would be a tricky drive through for sure.....
Michelle & Leon
New England Unit
05-15-2009, 07:40 PM
#27
Rivet Idiot
1999 34' Excella
On The Lake
, Georgia
I think I have everything ready to go now with the building. It will be 36'X45' with a 12'X45 overhang that is not enclosed. Doors will be 14' high and close to
15.5 in the center. Should give me plenty of room. Should be able to go up late July or early August. It is a steel building which will need to be ordered, made & delivered which they can not do until the permits get issued. I did not know this but they will put the building up, then pour the slab. That will give me a lot of time to work on how I want everything set up as far as plumbing, electrical, and stuff like dust collection.
Thanks again for the input and keep the suggestions coming. I'll try to post a layout with doors & windows as soon as I can get it.
Joe
08-25-2009, 05:57 PM
#28
Rivet Idiot
1999 34' Excella
On The Lake
, Georgia
Almost finished
The Morton folks came last week and I almost have my shop built. I think it is tall enough. The concrete folks will be here tomorrow and will pour the floor next week. Should be done by the end of next week.
Then, my work will start with the power and setting up the work spaces.
It appears they did an excellent job.
Thanks again for the input. I guess I need to move the thread somewhere else or start a new one on finishing "Maude's" house.
Annette
08-25-2009, 06:33 PM
#29
Vintage Alum. Enthusiast
1959 24' Tradewind
Phoenix
WOW!!! Is that ever nice. I'm totally green with envy.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
08-25-2009, 07:36 PM
#30
Vintage Kin
Fort Worth
FF
I'm close enough (but not quite murderous).
I sure appreciate all the ideas posted, gentlemen, as the farthest I had gotten was 14' door clearance; 40' deep to handle a 34' with ease; and electric/sewer/water inside as well as on an outside pad.
I especially like the idea of running air collection/other thru slab. I already knew a compressor would go outside, as I also wanted a home backup generator to occupy a similar space (according to code, etc.) so as to keep overall footprint down.
My expectation is that electric vehicles will be along in a while, so I was thinking of fairly serious amounts of juice available, as, ideally, there would be no separate garage for cars but this one building.
A kitchenette is a must, as is a shower/tub to wash dogs, etc.
09-07-2009, 07:05 AM
#31
Rivet Idiot
1999 34' Excella
On The Lake
, Georgia
Update: Maude safely in
Moved Maude in her new home this morning for the first time. Plenty of room to work! First up reseal the top around the vents now that I do not have to worry about the almost daily thunder showers.
Annette
09-07-2009, 07:31 AM
#32
1959 24' Tradewind
Phoenix
I don't know if you can all see it, but Maude has the biggest smile. She looks very comfortable in there. Now that she's in the photos for scale, the barn looks even bigger. Keep posting your photos and some interior layout plans.
Congratulations, she's a beauty!!
FF
09-07-2009, 07:52 AM
#33
2011 34' Classic
Westchester Cty.NY
, / Miami FL
wow, that's great!
Ricky
09-08-2009, 09:06 AM
#34
2005 25' Classic
Austin
What a great garage for Maude. We have our AS in an insulated garage, but almost need to use a shoe horn to get it in. We are planning to buy some property where we can build a much larger and taller garage for our AS in about a year. Your pictures and building progress were really appreciated.
Dennis
09-08-2009, 11:42 AM
#35
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
I gotta get me one of those. I'm very jealous.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
09-09-2009, 06:10 PM
#36
Ottawa
, ON
Well, Joe, I'd say you made it tall enough
Beautiful building, I'm joining the lineup of jealous AS owners.
09-09-2009, 06:12 PM
#37
1963 22' Safari
2020 27' Globetrotter
State of
Careful, she might get lonely in there any you may end up with two. Can only dream of having that much space to work, let alone under cover, nice job!
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
09-09-2009, 07:29 PM
#38
2000 28' Excella
Stewartstown
, Pennsylvania
I also built a pole barn for our Airstream the contractor erected it in 2 1/2 days. A week later I had the slab poured. It is wonderful. Our Airstream is out of the weather and the berry laden bird bombers. Big is always better when it comes to Pole barns. You did the correct thing.
09-09-2009, 07:34 PM
#39
1962 28' Ambassador
1962 30' Sovereign
Webster Groves
, Missouri
Careful going with 2 ... before you know it there will be a whole litter of Bambis!
09-10-2009, 06:19 AM
#40
Rivet Idiot
1999 34' Excella
On The Lake
, Georgia
Not going to happen.....To get DW's approval for this, I had to under go the dreaded alumasectomy procedure to keep these things from multiplying. However these are not 100% 100% of the time and modern science is having excellent success in reversals.
....if I angled Maude a little to right, Bambi would fit in the .....back Maude up the side ramp, Bambi in...more room to wor..
Stop it before I'm full timing in the shop!
Thanks for all the comments,
Joe
Annette
