Old 08-19-2012, 10:50 AM   #1
1987 31' Excella
Tucson , Arizona
How do you replace window glass
We just acquired a 31 foot 1987 Excella Airstream trailer. There are 2 side windows that open and 2 small fixed oval windows that need repair. Do I have to drill out the rivets? Any advice or suggestions is appreciated. And where do I get replacement glass?
Higgi
Higgi is offline   Reply With Quote
Old 08-19-2012, 11:09 AM   #2
Jerky guy
Jerky guy's Avatar
Springtown , Texas
Higgi
Yes you do have to drill out the rivets. I'm pretty sure inland rv carries the replacements but if you haven't done this before I hear it's not an easy chore! Just pull up inland rv .com
Jerky guy is offline   Reply With Quote
Old 08-19-2012, 11:17 AM   #3
Higgi
There are two types of oval windows that do not open.
The one on the top of an opening window is called "vista view".
The one underneath the opening window is called a "stack window".
They are the same width, but the stack is flat and the vista view is curved.
In either case, they must be drilled out.
A replacement will have the metal already around the glass.
The "glass" only will never be sold by Airstream.
You will need a package of Olympic rivets and a tube of Vulkem sealer in order to do the job, plus a pop river gun and a way to shave the rivet heads down.
Also, those windows are available in 4 different widths, therefore you must spec which size you need.
Old 08-20-2012, 01:14 PM   #4
1987 31' Excella
Tucson , Arizona
Thanks so much for the help, Jerky Guy and Inland RV. That takes care of the information regarding the small oval windows.... now how do I fix the two larger opening windows???
Higgi
Old 08-20-2012, 02:32 PM   #5
Higgi
The fix is easy.
You replace them.
What widths are you needing?
