Old 09-01-2014, 09:21 PM   #1
Glendale , California
How do you jack up a Curtis Wright/Early Airstream?
I wanted to jack up my Curtis Wright today to take a look underneath. I remember that the guys that put temporary used tires on it at a tire shop had trouble getting the CW jacked up. There doesn't appear to be a very sound place to put the floor jack. I believe the tire shop just put the jack under the leaf spring bolt and crossed their fingers. Turns out that the tire was a little too wide to slip between the hub and the fender skirt. They tried jacking the axle but no luck. The tire wouldn't fit. I thought about flipping the axle but that seems to be a whole new can of worms. How do you guys jack up old tube frame Airstreams or CWs? Thanks for any tips. Chris
chris hart is offline   Reply With Quote
Old 09-01-2014, 09:46 PM   #2
68Streamline's Avatar
Cerritos , California
Hi Chris,
On my 47' I place the jack behind the wheel where the steel support above the leaf springs meet with the c channels.
68Streamline is offline   Reply With Quote
Old 09-01-2014, 10:04 PM   #3
Thanks for the reply! I looked at that area and saw that about 2" of aluminum C channel (outrigger) extends below that metal plate. It seems like the jack might crush the outrigger up and into that metal plate. Is that outrigger much beefier than the others? I would think so since the whole suspension seems to be attached there. Do you use a piece of plywood to help distribute the weight and avoid damaging the belly pan? My belly pan isn't that great so no worries there! Chris
Early Airstream and Curtis Wright interior paint colors chris hart Upholstery, Blinds, Walls & Interior Finishes 2 11-11-2014 10:39 PM
Curtis Wright and Early Silver Streak beds chris hart Vintage Kin 7 03-31-2014 08:34 AM
Curtis Wright Article: Airstream Life cuyeda Vintage Kin 15 02-27-2008 12:48 PM
