Old 05-23-2009, 09:14 PM   #1
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
How do you get Vulkem off?
We've removed the old Armstrong air conditioner from our '66 Safari, and we're trying to clean up the area and reinforce the roof before we install the new Carrier. The sealer that was used around the old A/C is pretty stuck.
Does anyone know an easy way to get Vulkem off?
Thanks.
Old 05-23-2009, 09:19 PM   #2
jpeterman's Avatar
1972 27' Overlander
Graham , North Carolina
i removed a ac unit and used a hair dryer to heat the material, but I'm not sure if it was Vulcum or a less stuck material
good luck on this
"AIR 17559"
wear it out, don't rust it out
Jerry
jpeterman is offline   Reply With Quote
Old 05-23-2009, 09:54 PM   #3
cameront120's Avatar
1972 25' Tradewind
I use popsicle sticks, that I've sharpened at one end, and use them as scrapers to get most of the vulkem off. Solvents are hit and miss, I find. None that I've tried completely remove it.
North Vancouver, BC
Old 05-23-2009, 11:21 PM   #4
Potters , Idaho
I re-sealed my top last year and I used a heat gun on a medium setting and popsicle sticks. It worked great. Once I got most of it off I used a rag with acetone. Keep the heat gun away from the acetone.
phoney is offline   Reply With Quote
Old 05-24-2009, 07:22 AM   #5
Crusty's Avatar
1992 34' Excella
A stiff putty knife and lots of elbow grease. The best technique seems to be rocking the handle side to side while pushing with a moderate amount of force. Applying some heat will soften it some and make the process go faster.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 05-24-2009, 07:50 AM   #6
If it really is vulkem (polyurethane sealant) then WD40 works well on it.
And the other methods mentioned above all work too, medium heat and some sort of non-metal scraper. Once you get down to just a fine residue, you could use MEK as a solvent to get the aluminum to a really clean state, just be really careful with it and be sure to wear mask and gloves when using it.
Good luck!
Old 05-24-2009, 08:02 AM   #7
navyeod's Avatar
1958 26' Overlander
1991 29' Excella
auburn , Alabama
wd-40
Some on this forum told me of the wd-40 trick. Worked great putting the solvent on for a few minutes and then taking a scraper and removing the foamy residue. I too was going to put acetone or some solvent on to remove the wd-40 prior to recaulking. I could not believe the difference the WD-40 made.
navyeod is offline   Reply With Quote
Old 05-24-2009, 09:06 AM   #8
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
A PO had used much silicone, a no-no on aluminum, all over our Trade Wind (but we have very few leaks) so after 3 years of cleaning I kinda know what works. First do NOT use a a metal scraper. It will create very difficult scratches to remove. I use tongue depressors shaped into a scraper and plastic spatulas. If you indeed have silicone it is very difficult to disolve and remove. There are silicone removers available at your local hardware but I like Gasket Remover which can be found at your local auto supply.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 05-25-2009, 10:23 AM   #9
Potters , Idaho
Has anyone ever tried paint remover?
Old 05-25-2009, 02:53 PM   #10
1976 31' Excella 500
New Castle , Indiana
I just bought a set of scrapers at harbor freight that work well for removing vulkem.
They are plastic and can be resharpened. Here's a link if you are interested.
- Harbor Freight Tools - Quality Tools at the Lowest Prices
TravisA is offline   Reply With Quote
Vulkem? RandyG Exterior Restoration Forum 8 09-08-2009 01:45 PM
Anyone need some Vulkem bmklawt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 02-27-2009 07:16 AM
Vulkem? Annemac 2006 Safari 3 05-17-2007 02:34 PM
Vulkem '70verlander Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 08-25-2006 04:32 AM
How much VULKEM??? Buttercup Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 08-19-2005 12:44 PM
