Old 06-06-2015, 03:51 PM   #1
2001 34' Excella
Edinburg , Texas
how do I replace pull tab
I pulled the loop off of my door side large Zip Dee awning. How do I extend the Awning now, so that I can reattach the pull loop? This should be a simple fix if I can just get it extended to work on it.
jbailey01 is offline   Reply With Quote
Old 06-06-2015, 04:08 PM   #2
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Get a buddy and each of you get on an awning support arm and pull out evenly until the awning is out.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 06-06-2015, 04:33 PM   #3
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Zip-Dee sells a replacement and it comes with rivets to install it. Works great. With a little help I think you can get awning out to find the tail that's left. Get the replacement first though. For the short term I just tied a short piece of rope on it until I got around to putting the replacement on.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 06-06-2015, 04:55 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Two people to pull it out. Last rally I riveted a torn strap back on a neighbors ZD. His entire awning was so rotten that it tore right back off. Hopefully he has recovered the awning by now.
MICHAEL
Old 06-07-2015, 07:11 AM   #5
2001 34' Excella
Edinburg , Texas
Thanks to all of you. Air Forums is such a help,when you have to face a new issue. Almost always someone else has delt with the same problem.
Old 07-26-2015, 08:52 PM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
On my Safari the loop at the end of the awning center strap has torn. Last week when I tried to open it with the pull bar, it ripped right through the cloth. I do not want to replace the whole strap, so I'm hoping to find another solution. I'm thinking about using some awning cloth to create a new loop and sew it onto the existing strap by hand. I need to find the correct materials. The pull strap on my Safari is a black woven nylon looking fabric.
Has anyone else done this, just added a new looped end?
I've sent an email to Zip Dee requesting assistance. Hoping to hear from them soon.
Alan
A W Warn is online now   Reply With Quote
DIY glue pull tab dent puller on the cheap. outofcontrol Ribs, Skins & Rivets 19 12-16-2016 09:27 PM
Dutchmen, T@B, Tab, Tear Drop trailer, Tada, Thor, Camper, RV, Airstream eBay Watch Airstreams on eBay 0 10-04-2011 10:30 AM
1982 Airstream 280 timing tab two72 Mechanics Corner - Engines, Transmission & More... 1 06-01-2010 01:58 PM
Tab Problems azflycaster Forum Admin, News and Member Account Info 11 02-09-2007 11:37 AM
Dutchman TAB Chitown AirStreamers Our Community 3 09-15-2003 04:32 PM
