Old 06-23-2015, 05:05 PM   #1
2013 23' International
madison , Wisconsin
how do I fix this?
The leading edge of our Irving folding door in our Serenity has come out of the track. The photos show that the plastic tab has broken and wonít stay in the track. I canít fine any replacement parts on the web. Current plan A: get a suitable plastic washer, cut a slit in it, slip it over the tab and try to cram into the track. I hope someone has a better idea. Thanks. PS. Photo maybe displayed at 90 degree rotation.
Name:	RV folding door.jpg
jim1949 is offline   Reply With Quote
Old 07-01-2015, 09:02 PM   #2
2002 19' Bambi
2004 25' Safari
Paris , Illinois
I had same thing break on our Bambi. I called Irving and explained what I needed and they sent a new plastic tab and a brass rivet. Drill out the old rivet and use a hammer and punch to peen the new rivet and tab in place. Have them send you 2 of each part as it will break again. It breaks because the plastic rivet is not strong enough to take the weight of the leading edge of the curtain as you bump and bounce down the road while towing. I cured this by putting a 2x4x4 inch block of foam rubber under the leading edge of the curtain when it is not in use and we are towing. This way the curtain is supported and the rivet is not taking all the weight. I will add that you will have to remove the track to slide the leading edge back on the track then reinstall the track.
nipsey is offline   Reply With Quote
Old 07-02-2015, 05:32 AM   #3
madison , Wisconsin
nipsey
great idea! thanks.
Old 07-02-2015, 06:42 AM   #4
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Nipsey, thanks for the recommendation. A little cushioning support goes a long way.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
To fix or not to fix nayl Ribs, Skins & Rivets 16 07-17-2010 08:38 PM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 07:50 AM
Broken Lite Shade Fix wagsrp General Interior Topics 1 10-13-2002 09:11 AM
How do you fix the entry step. rdm Airstream Motorhome Forums 2 07-14-2002 09:16 PM
wiring fix? ALANSD Airstream Motorhome Forums 9 06-20-2002 07:40 AM
