Old 12-15-2015, 05:01 PM   #1
Cardinal283's Avatar
Dallas , Texas
How bad is this idea??
So I've been pondering insulation and such as I'm mentally gearing up to replace the interior skins. Regardless of how well I insulate the walls there is still a direct conductive hear transfer from the exterior skin to the ribs to the interior skin and vise versa depending on temps. I had been contemplating a thermal break between the interior skin and the ribs such as putting a sheet of prodex over the ribs as I put the interior skins on. I think it will compress the prodex where the rivets are and may cause bubbles or waviness where it isn't compressed between the rivets. So I'm shying away from the prodex idea. But if I had a material that wasn't spongy or compressible that would also serve as an effective thermal break I'd be more likely to try it. What are other people's thoughts and ideas in this?
Cardinal283 is offline   Reply With Quote
Old 12-15-2015, 05:55 PM   #2
cameront120's Avatar
1972 25' Tradewind
Regardless of the material used, the rivets will still provide points of thermal bridging through the assembly. I'd avoid anything organic for obvious reasons. You might try strips of EPDM (synthetic rubber used for roofing). It comes in various thicknesses from 45mil to 90mil. We use this material to protect vertical wood strapping from weather exposure prior to applying siding in reinsure applications.
North Vancouver, BC
Old 12-15-2015, 06:15 PM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Try contacting Colin Hyde to ask his opinion. I know he uses some form of thermal break on his remodels, I just can't recall what he does.
Bob Martel
WBCCI# 5766
Old 12-15-2015, 07:31 PM   #4
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
That has been tried before, I've seen someone mention it somewhere on the forums....the added thickness of prodex would cause your exsisting holes in your wall panels to not line up with the ribs holes. Another fellow used silver duct tape and he had the issue of he couldn't see where his existing holes were in the ribs when it came time to put the wall back on. He got fed up pulled the panels and ripped the tape off. When I did mine I used bright blue insulating electrical tape. I taped it on the ribs then rubbed my thumb along the ribs to find where the rivets holes go through and I went around with a fine tipped exacto knife and trimmed each circle out so when it came time to put my walls back in I had zero issues. I cannot recommend enough how handy Clecos are, I would have been very sad if I did not own these... Spring Clecos
thesignlady is offline   Reply With Quote
Old 12-15-2015, 07:44 PM   #5
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Can't seem to find my close up but this is what it looked like.
Old 12-15-2015, 09:15 PM   #6
Central , Mississippi
I overlayed the ribs with prodex on 2 trailers so far. Both have all new interior skins so lining up holes was a nonissue. My personal trailer has 20,000 miles on it and has only popped 1 rivet to date. On it, I used .025 thick 3003 aluminum for the interior because it was all I could get locally. It lays nice and flat but does dent easier then the .032 I have since used. I did use a closer rivet spacing than stock. So far I'm very pleased with the result. I can't empirical say if the thermal properties are better but the install is much faster than fitting the second layer between the ribs.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 12-16-2015, 12:36 PM   #7
mykytiukr's Avatar
1965 24' Tradewind
almena , Wisconsin
Insulation
Sheets of asphalt soundproofing material comes to mind. Check out The Soundcoat Company, world leader in sound insulation and noise control
mykytiukr is offline   Reply With Quote
Old 12-16-2015, 01:36 PM   #8
JRF0st3r's Avatar
1967 22' Safari
West Fork , Arkansas
Similar to the sign lady, we used a good quality gaffer's tape over all the ribs except we left it off where there were rivet holes so our Clecos could find a home. Cameron is right that the rivets have no thermal break but most of the surface area does.
For insulation we chose mineral fiber (aka rockwool) batts. Walls were done starting with 3" thickness then slicing down to 1 1/2" with an electric carving knife.
JRF0st3r is offline   Reply With Quote
Old 12-16-2015, 04:17 PM   #9
TAC CA-420
'55 Airlight's Avatar
Santa Monica , California
Images: 104
Originally Posted by JRF0st3r View Post
... we used a good quality gaffer's tape over all the ribs...
(Gaffer's tape, huh? Q:You know the difference between a gaffer and a cinematographer? A About $3000/week.)
Michael
"Of the gladdest moments in human life, methinks, is the departure upon a distant journey into unknown lands... A journey, in fact, appeals to Imagination, to Memory, to Hope,—the three sister Graces of our moral being.’
Sir Richard Francis Burton
'55 Airlight is offline   Reply With Quote
Old 12-16-2015, 07:47 PM   #10
Dallas , Texas
I'll be putting in new aluminum. So the old holes are a non issue.
I had considered using the fiberglass wrap that is used to wrap engine exhaust pipes near heat sensitive objects. Any thoughts on that idea?
Old 12-16-2015, 07:49 PM   #11
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
Why not replace the upper ribs with homemade carbon fiber ribs. I estimate you can create a 12 foot rib for about $200. You need the original rib for the mold and some 4" carbon fiber tape, epoxy and a simple vacuum system.
FC7039 is offline   Reply With Quote
Old 12-16-2015, 08:24 PM   #12
Dallas , Texas
Yeah. I'll get right on that. 😂
Old 12-16-2015, 08:43 PM   #13
reinergirl's Avatar
Hollis , New Hampshire
I used. 1/32 double sided foam tape . See my post 563 here.
http://www.airforums.com/forums/f109...ml#post1565193
It did make finding the holes a real bear! I know that in the heat of the summer there was considerable difference in the the temp of the front of the rib where the tape was vs the sides of the rib.
reinergirl is offline   Reply With Quote
Old 12-16-2015, 08:55 PM   #14
Mission , Texas
Given walls ~1-1/2" thick with fiberglass insulation for a whopping R 5.7 why bother?
Just curious ...
Really.
nrgtrakr is offline   Reply With Quote
454 TBI, yes/no good/bad idea? bkahler Mechanics Corner - Engines, Transmission & More... 162 06-20-2016 08:00 AM
Total electric. Good idea or bad idea? EZstream Generators & Solar Power 34 08-17-2011 08:40 PM
Is This a Bad Idea? Raptorrider2001 General Repair Forum 14 06-29-2008 12:52 PM
My latest bad idea.... Boondocker Winterizing, Storage, Carports & Covers 3 11-01-2006 08:12 AM
removing interior walls: bad idea? pinkflamingoes General Interior Topics 45 07-14-2004 08:18 AM
