Old 01-07-2016, 08:09 PM   #43
DFlores's Avatar
1968 22' Safari
Name:	ImageUploadedByAirstream Forums1452222511.220133.jpg
I don't know math, but my numbers add up OK
Prodex
Sent from my iPhone
David & Diane
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 01-07-2016, 09:05 PM   #44
Central , Mississippi
Yup. Numbers don't work. My in-fra-red showed not much of a gain from prodex panel to a bare panel.
But
The bare panel burned my hand.
The prodex was cooler to touch.
Dunno.
After 2+ years of use, my prodex camper stays as cool as my other standard insulation Airstream (and there are no odors after a few weeks of hot temp non-use...the other insulation still smells like "old guys" according to Ms HiHo. Wait. That's my smell...)
Anyway, IMHO the only drawback to Prodex is sound deading.
Entire reply typed while listening to rain on the roof. Zzzzzzzz.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-07-2016, 09:17 PM   #45
Cardinal283's Avatar
Dallas , Texas
Hahaha. Touché David/Diane.
See previous statement about anecdotal evidence. Lol.
Cardinal283 is offline   Reply With Quote
Old 01-07-2016, 09:19 PM   #46
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
Here a poorly done (by me) video
I had a second video where I had a rib in the test but cannot find it
FC7039 is offline   Reply With Quote
Old 01-07-2016, 10:00 PM   #47
Dallas , Texas
Interesting, but not surprising, that the ceramic paint seemed to radiate more heat than the control box with bare aluminum.
Aluminum is an excellent conductor of heat from one surface to another but it is terrible at radiating that heat through space (this is why prodex works - there is no appreciable R value contributed by it). When coated with the ceramic I would speculate that the exterior aluminum conducts the heat to the ceramic coating which is apparently much better at radiating that heat to the inner skin.
I would be interested to see the same tests done with a thermal break between the rib and the inner skin to determine the best thermal break. Then repeat your experiment with the insulation with that thermal break.
Old 01-07-2016, 10:01 PM   #48
Dallas , Texas
Great tests by the way! I might be inclined to repeat your tests for verification purposes.
Old 01-07-2016, 10:53 PM   #49
FC7039's Avatar
Allen , Texas
I was surprised at the micro balloon paint performance and surmised as you did that the increase in radiant heat was the issue. It probably works better where you may contact a surface but not as a space insulation.
You may also want to polish the inside ceiling as shiny aluminum will radiate far less than painted.
Old 01-07-2016, 11:01 PM   #50
FC7039's Avatar
Allen , Texas
This all goes back to this thread several years ago
http://www.airforums.com/forums/f478...ml#post1104741
Old 01-07-2016, 11:18 PM   #51
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
I gotta say that was a pretty well done poorly done demonstration. Thanks for sharing. If you get bored feel free to test Roxul stonewool insulation, that's what I put in mine, I'm curious how it compares.
Also thinking of the climate differences between the different locals of Airstreamers. I am a fall, winter, spring boondocker in Canada. Is prodex much use for keeping heat in as well?
thesignlady is offline   Reply With Quote
Old 01-08-2016, 12:34 PM   #52
Dallas , Texas
I didn't realize the video used a wood frame instead of aluminum ribs. That's what you were saying about the ribs in the second video you can't find.
Old 01-08-2016, 04:03 PM   #53
FC7039's Avatar
Allen , Texas
I used the wood as it would not transfer the heat. I think too much thought goes into the insulation. I think a bubble foil or other standard insulation is fine. I think you are on the right direction with trying to prevent the ribs from syncing the heat to the inner skin.
Old 01-08-2016, 05:41 PM   #54
Dallas , Texas
I would like to redo your test and compare a non conductive rib such as wood to a conductive rib such as aluminum. Just to determine how much of the heat on the interior skin comes from radiant heat and how much comes from conduction. Possibly try another set of experiments with Prodex and even try different numbers of layers and configurations.
Old 01-08-2016, 05:50 PM   #55
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
I'd like to see how one with spray foam would fair
Matt
rugjenkins is offline   Reply With Quote
Old 01-08-2016, 05:57 PM   #56
Dallas , Texas
I'm curious about the spray foam too. How would one normally go about applying spray foam to a trailer? Drill a hole for the spray tube to fill the hollow area? Spray it on to the inside of the outer skin with the inner skins off then shave it all down to an even 1.5" thickness before putting the inner skins back on?
454 TBI, yes/no good/bad idea? bkahler Mechanics Corner - Engines, Transmission & More... 162 06-20-2016 08:00 AM
Total electric. Good idea or bad idea? EZstream Generators & Solar Power 34 08-17-2011 08:40 PM
Is This a Bad Idea? Raptorrider2001 General Repair Forum 14 06-29-2008 12:52 PM
My latest bad idea.... Boondocker Winterizing, Storage, Carports & Covers 3 11-01-2006 08:12 AM
removing interior walls: bad idea? pinkflamingoes General Interior Topics 45 07-14-2004 08:18 AM
