Old 12-16-2015, 09:23 PM   #15
Cardinal283's Avatar
Dallas , Texas
The double sided foam tape seems like a great idea. Thanks.
Cardinal283 is offline   Reply With Quote
Old 12-16-2015, 09:28 PM   #16
Dallas , Texas
Originally Posted by nrgtrakr View Post
Given walls ~1-1/2" thick with fiberglass insulation for a whopping R 5.7 why bother?
Just curious ...
Really.
R5 sure beats R0. Especially in 105 degree heat. Plus if I can prevent thermal transfer from the exterior skin to the interior skin my AC unit will be able to keep up better on Texas summer days. R5 might not seem like a lot. But when you add up all the little things like insulation, thermal barrier on the ribs, low E windows, curtains, awning, a roof coating it all equals many degrees cooler inside the trailer.
Old 12-16-2015, 10:59 PM   #17
1971 31' Sovereign
Temple , Texas
Has anyone actually recorded any data on the effectiveness of this "thermal break" modification? No disrespect intended. I freely admit I have zero knowledge on this topic. I'm just curious.
TxDave is offline   Reply With Quote
Old 12-17-2015, 07:04 AM   #18
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by '55 Airlight View Post
(Gaffer's tape, huh? Q:You know the difference between a gaffer and a cinematographer? A About $3000/week.)
Michael
Good one Michael!!!!!😁
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters
541-490-6357
Old 12-17-2015, 09:43 AM   #19
cameront120's Avatar
1972 25' Tradewind
It must be effective because all modern building codes are requiring thermal breaks in windows and the reduction of thermal bridging in building envelopes. All you need to do is look at the energy bills comparing a standard stick built home compared to a home using more sophisticated detailing and construction techniques. For example, the Passivhaus building standard reduces energy consumption for heating and cooling by up to 90% by careful use of insulation, efficient windows and elimination of thermal bridges (a thermal break is but one component of this strategy).
North Vancouver, BC
Old 12-17-2015, 12:25 PM   #20
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
I like the exhaust tape idea.
I bought ceramic insulating additive that u mix with paint. I'll use the ace galvanize metal and aluminum paint then add the ceramics. It's fairly cheap and easy to use. I saw where someone on the forum used it, they also painted a light bulb and were able to hold it in there hands and felt no heat. The plan is to paint the whole interior and then spray foam for insulation. 😄
Matt
rugjenkins is offline   Reply With Quote
Old 12-17-2015, 04:50 PM   #21
KEIZER's Avatar
1980 31' Excella II
1973 31' Sovereign
Noonan , New Brunswick
I am in the process of deciding about spray foam for my trailer also. I like this idea of the ceramic insulating additive. Where do you get this?
WBCCI #6722
Ham Radio VE9NKD
KEIZER is offline   Reply With Quote
Old 12-17-2015, 10:19 PM   #22
TAC CA-420
'55 Airlight's Avatar
Santa Monica , California
Images: 104
Just curious ...
Really.
Especially on 1-1/2" thick walls, there's lots better insulation than fiberglass. But I've been thinking the same thing about diminishing returns on these elaborate measures described. What kinda extreme conditions is the original poster anticipating?
Michael
"Of the gladdest moments in human life, methinks, is the departure upon a distant journey into unknown lands... A journey, in fact, appeals to Imagination, to Memory, to Hope,—the three sister Graces of our moral being.’
Sir Richard Francis Burton
'55 Airlight is offline   Reply With Quote
Old 12-18-2015, 09:40 AM   #23
1972 25' Tradewind
If the skins are off, there's really nothing elaborate about these measures. Seems the ideal time to use modern technology to improve upon a less than modern design. Will it add a huge amount of R-value to the assembly. Nope (unless you can afford aerogel), but every little bit will help. Especially if you can successfully introduce a thermal break from the ribs to the interior skin. Of course, people could always settle for these being 3-season trailers and leave well enough alone.
North Vancouver, BC
Old 12-18-2015, 10:18 PM   #24
rugjenkins's Avatar
1975 Argosy 28
Hytech thermal solutions. It's on the web
Matt
Old 12-18-2015, 11:46 PM   #25
Dallas , Texas
The extreme conditions I anticipate are called Texas summers. 110F. No shade. If a thermal break reduces thermal transfer of heat from the exterior skin to the interior skin by a couple degrees it's worth the time and money since I already have the skins off anyway. Why not try it?
Maybe I'll leave one rib without the thermal break so I can use my laser thermometer to see if there is a difference.
Old 12-19-2015, 07:39 AM   #26
TAC CA-420
Images: 104
Yes, those are extreme conditions. I must've missed the thread's since-I-already-have-the-[interior]-skins-off-anyway remark.
I don't have air-conditioning. I anticipate that one of the virtues of my new solar panels will be the shade they create on the exterior skin (under them) thus keeping the trailer interior cooler.
Best,
Michael
Old 12-19-2015, 08:55 PM   #27
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
I've used the hytech beads - think non-skid paint additive, not a good thing to have between two soft aluminum structures that creep and vibrate. Where the beads excel is where temperature difference potentials are greatest, unlimited sunshine and roofing or steam pipes and cold air.
Please remember that aluminum itself does not radiate infrared as most materials do, something with the molecular size and IR light wavelengths - so any coating (even dust or oily film, etc.) applied to bare aluminum will amplify heat transmission via radiation (along with conduction and convection) - so the gains of painting may be slight, plus then loosing the reflective properties of bare aluminum to bounce heat back to source or loosing the smooth metal surface that keeps a portion of heat transferring via convection by having the smallest surface area.
I know, how far to carry on with re-engineering ...
If you do use spray foam you'll need to caulk any and all gaps between ribs and shell or overlapping edges with gaps, anywhere a gap can trap resins that continue to foam and WILL deform the shell when something gives. Even with minute micro area pressures once square inches of surface are involved sheet metal will yield to ripple things visibly from the outside.
If you do use a thermal break remember if it yields under rivet crush pressure you'll have a bazillion birds eye dimples around the rivets. If you use the VHB foam tape one could always put a drop of paint or epoxy at the drill bore to soak into the foam pores and harden to reduce that, just more detail work.
Also - the choice of materials might make a grass or trash fire into a catastrophe. Aside from fire dangers I'd be leaning toward the flexible cutting board material 'High Density PE Smooth 1/16 x 48"x96"' (.0625" $50) Sheet cut into strips... HDPE can handle 110°C /230°F continuously but will melt and pool at higher temperatures. Oops.
What I last glommed onto was some rolls of Mylar fiberglass reinforced electrical insulation tape, has low fire & toxin hazard & low mechanical compression and is nearly inert but sadly is just better than nothing in stopping the flood of conductive heat. I figure two layers on the bows ceiling curves will help without being too much trouble.
Keep posting your ideas and don't fatigue!!
Old 12-20-2015, 11:39 AM   #28
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
Do you plan to used the paint on the ribs or on the entire inner skins?
FC7039 is offline   Reply With Quote
454 TBI, yes/no good/bad idea? bkahler Mechanics Corner - Engines, Transmission & More... 162 06-20-2016 08:00 AM
Total electric. Good idea or bad idea? EZstream Generators & Solar Power 34 08-17-2011 08:40 PM
Is This a Bad Idea? Raptorrider2001 General Repair Forum 14 06-29-2008 12:52 PM
My latest bad idea.... Boondocker Winterizing, Storage, Carports & Covers 3 11-01-2006 08:12 AM
removing interior walls: bad idea? pinkflamingoes General Interior Topics 45 07-14-2004 08:18 AM
