Old 08-20-2019, 04:53 PM   #1
TAMPA, FL , FL
Houston we have a problem
Hello All - New to community and already need your help.
We just purchased a 2014 25' Flying Cloud from a private owner took our new baby to the Airstream dealer with instruction to go over and advise what was what. When completed with their list we gave them the green light to do everything on the list except for cosmetic stuff. Now here we are 1000 miles away and discovered a leak. It appears that the black plastic tank that's banded by metal has two small holes (pictured). Can someone identify the what this tank holds and what we need to do to remedy.
thanks in advance.
Name:	25' flying cloud leak.jpg
ID:	350016   Click image for larger version
Name:	Screen Shot 2019-08-20 at 6.49.09 PM.jpg
Name:	Screen Shot 2019-08-20 at 6.49.40 PM.jpg
ID:	350019   Click image for larger version
Name:	Screen Shot 2019-08-20 at 6.50.27 PM.jpg
Shortmoney is offline   Reply With Quote
Old 08-20-2019, 05:34 PM   #2
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Wow. That looks like your freshwater tank but something is very wrong. There is no metal shroud/ tank cover. Looks like someone replaced the. Tank with an aftermarket tank and did not reinstall the tank cover. It should look like this.....
Here’s a pic of mine dropped. Note where the metal straps where located.
Airstream Ambassador
Instagram @Airstream_Nuts_And_Bolts
Airstreamnutsandbolts@gmail.com
Dept of “Overkill”
Old 08-20-2019, 05:39 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Look at your valves and see which valve is attached to that tank. Have you recently filled the fresh water tank? Sometimes the fill hose leaks when the fresh water is full.
Old 08-20-2019, 07:37 PM   #4
Iansk's Avatar
1977 31' Sovereign
Sunset Valley , Texas
Could that be a cover? In one picture the hole (which is obviously too perfect to be accidental) is adjacent to what looks like a diverter. Possibly it’s the fresh water overfill drain?
Most curious indeed...
Ian
Iansk is offline   Reply With Quote
Old 08-20-2019, 07:41 PM   #5
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
I suspect you are missing your low point drains. I will get a pic of mine and post in a few mins..
Gsmblue is offline   Reply With Quote
Old 08-20-2019, 07:43 PM   #6
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Is that a tank shroud or an aftermarket tank?
Dept of “Overkill”
Old 08-20-2019, 07:44 PM   #7
Gsmblue's Avatar
Bend , Oregon
Here you go. These are located on the passenger side on my 2015 25ft RB..
Apologies for the gravity defying pic.. joys of posting from the smarty phone...
Old 08-20-2019, 07:49 PM   #8
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Pic fix
Dept of “Overkill”
Old 08-20-2019, 07:49 PM   #9
Gsmblue's Avatar
Bend , Oregon
And the view from the other side. Probably also defying gravity...
Old 08-20-2019, 07:50 PM   #10
Gsmblue's Avatar
Bend , Oregon
Thanks GMFL!
https://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowboarding habbit, mwah-ha-ha . . .
Old 08-20-2019, 07:51 PM   #11
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Welcome.
I learned something new. I’ve never seen a plastic tank shroud.
Dept of “Overkill”
Old 08-20-2019, 07:54 PM   #12
Gsmblue's Avatar
Bend , Oregon
Right, nor had i before this! I did lose a drain during a cold snap, the dealer replaced it for me while doing other warranty work. So I know what the problem is but as I didn’t fix it myself i am not able to advise any further! Hopefully someone else will step in.
Old 08-21-2019, 12:16 PM   #13
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
Hey, Shorty! Welcome.
Step 1: Take a deep breath... stuff like this is common with RVs.
Step 2: Gather facts, particularly facts that are relevant to your specific trailer. Consider what we pay for advice here on the Forum. That's precisely what some of it is worth.
I have essentially the same trailer that you have. I wrote an extensive post (profusely illustrated!) about that mysterious black box, what's inside it, and how to remove and replace everything in there. Here's a link: http://www.airforums.com/forums/f443...ml#post2166842
Now... what you have is undoubtedly a fresh water leak. That's all that's in or above that box. (For info on black water leaks and the mysterious galvanized tank in front of the black plastic one, watch for my upcoming post about replacing a black tank dump valve using only hand tools at a campsite... but I digress).
Inside that black box is a separate plastic tank to hold fresh water. That tank has four active connections (the fill tube, the vent, the water pump connection and the drain). The low point drain lines pass through the box and emerge through the bottom where the valves are attached. There are also water lines in the space above the tank.
Something in that series of hardware items is leaking on your trailer. The weep holes in the bottom of the tank enclosure are there to let leaking water escape. That's a good thing!
Question for you: Just how much fresh water are you leaking? I was losing about a gallon or two per day. I lived with that for a couple of trips until I had time, learning and a place to undertake repairs. Your leak may or may not require attention urgently. I'm inclined to think your situation isn't urgent.
The next step is to decide how you want to locate the source of the leak and repair it. The first step in that process is observational. It is quite possible that the water fill tube or its connection to the tank is leaking. Does the leak only occur after a fill up? Does it stop after the tank is drained down a bit? Or it could be the pump and it's lines. Does the leak stop when the system is depressurized or maybe stop when on city water as opposed to the pump?
In my case, a fitting at the bottom of the tank was cracked. Mine leaked all the time until it ran dry.
Digest that a bit. Send more questions as you have them or as you learn more about your situation.
GammaDog is offline   Reply With Quote
Old 08-21-2019, 03:23 PM   #14
TAMPA, FL , FL
GammaDog - Thank you for getting me down off the cliff.
After my purchase we drove the AS to our home in NC while we wait for septic tank fix and Duke to run power. So, it sits, not plug in to any power it's just waiting for permanent home . It's was raining for a few days when we arrived so my initial thought it was just the rain ..after several sunny days with a wet mark running down the drive. I crawled under to investigate and found 2 locations dripping ..The Holes! So, if I understand you correctly the black box is merely a container for another box that holds the fresh water? Do I need to remove black box to check the fittings you mentioned? Is this a job for a novice? I have tools and know which end of the screwdriver to hold but I'm not a wrencher.
Houston We Have A Problem Alcoa Roller Repairing/Replacing Floor &/or Frame 8 09-05-2014 10:03 PM
Houston We Have a Problem! The Flintstones Winterizing, Storage, Carports & Covers 13 12-05-2009 12:36 PM
Houston, do I have a problem? Becky B. Belly Pans & Banana Wraps 25 03-08-2009 03:46 PM
Houston... We have a problem! mabuofh Member Introductions 5 02-12-2007 01:04 PM
Houston we have air pressure! ALANSD Airstream Motorhome Forums 27 12-09-2003 05:35 PM
