Old 08-02-2009, 12:15 AM   #1
1979 30' Argosy
saint augustine , Florida
Rivet Houston..we are venting water?
so here goes, the 79 rear bath argosy has a leak that is drip.drip.dripping slowly from the right rear outside corner. i've looked under the sinks, as much as i can around the tub, but cannot find any clue from inside the bathroom. any ideas as to where i might look next. could it be the "brand new" water heater line? or some other antiquainted connection somewhere along that wall. And am i looking at tearing out the bottom skin to find my source. any sugggestions appreciated.
greenRNtrav. is offline   Reply With Quote
Old 08-02-2009, 02:52 AM   #2
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
A leak can telegraph from pretty far away to appear where it actually seen...
http://service.airstream.com/files/l...78a745c79d.pdf
Shows the bathtub over the RR corner... I know the trap on my '73 bathtub had given someone much grief, teflon pipe paste all over it and it appears they never could keep it tight... Sorry I can't be more help.
Old 08-02-2009, 07:20 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Does the leak only happen when attached to city water? There should be a pressure relief valve that might be leaking or you might have too much pressure.
Richard
Old 08-02-2009, 09:36 AM   #4
Images: 59
Check the third paragraph, then the restoration link.
markdoane is online now   Reply With Quote
Old 08-02-2009, 11:03 AM   #5
Alwhisman's Avatar
1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 94
Send a message via Yahoo to Alwhisman
My pressure relief valve was bad and gave a heavy steady drip when connected to city water. I removed it and havent found a replacement yet. It was installed inside (past) the regulator. From the inside it was hard to tell thats what it was until I really put some light on it.
Al
Alwhisman is offline   Reply With Quote
Old 08-02-2009, 09:50 PM   #6
1979 30' Argosy
Rivet
i would think that with my pressure regulator at the city water spicket set at about 40 psi, i would not be in any trouble , but i will check the valve...if only i knew where to look!!, i;ll send some pics in a couple of days. i have sort of isolated the leak from the outside, it's running down from up-under the plastic casing that girds that corner, then runs down along the bumper, and onto the ground. does this mean that it's NOT my holding tanks, or am i just not that lucky?
Grey water in a '71 Sovereign? CeloNC Waste Systems, Tanks & Totes 27 02-10-2012 09:16 AM
Elect/Propane Water Heater Combo dkottum Plumbing - Systems & Fixtures 4 12-11-2011 05:41 PM
Water pump running with no water! Michigander Fresh Water Systems 11 07-25-2011 03:04 PM
Atwood water heater fast cycling Skater Water Heaters, Filters & Pumps 4 07-22-2011 07:02 PM
Water heater won't lite aswbe Water Heaters, Filters & Pumps 6 06-06-2011 09:18 PM
