Old 04-13-2016, 08:26 PM   #1
1997 25' Safari
Nowata , Oklahoma
Hooking up water
I am completely new to this.... 1996 Safari
When I hook the water hose up do I need a regulator for pressure?
When the water is hooked up my grey tank ends up with water in it when I have not used any inside, why?
Is there a built in something that relieves the pressure on the lines inside and water just goes into my grey tank?
I have small drips around the road side wheel well.... NO idea why.
Please help...
SherryC is offline   Reply With Quote
Old 04-13-2016, 08:32 PM   #2
2015 28' International
Ofallon , Missouri
I can help with part of your questions.
Some Campgrounds will have water pressure that's too high. My AS has a pressure regulator built in that is supposed to protect your plumbing system (but not the hose connecting your AS to the water source). Personally I always connect a pressure regulator when I hook up. If I recall it was <$20 so worth it to make sure. I keep the regulator connected to a filter which I connect to the source, and I attach my hose to the filter.
mpsgolf is offline   Reply With Quote
Old 04-13-2016, 08:41 PM   #3
1997 25' Safari
Nowata , Oklahoma
Thank you! I will purchase one!
Old 04-13-2016, 09:38 PM   #4
2007 22' International CCD
Be sure to get an adjustable one. The cheap fixed ones can't handle a reasonable high flow rate.
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 04-13-2016, 11:39 PM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
(1.) When I hook the water hose up do I need a regulator for pressure?
(2.) When the water is hooked up my grey tank ends up with water in it when I have not used any inside, why?
(3.) I have small drips around the road side wheel well.... NO idea why.
Please help...
Hi,
(1.) I have a separate water pressure regulator to protect my water hose in camp grounds with very high water pressure. Your trailer has a built in pressure regulator so in most cases you won't need another one.
(2.) You could have a leaking faucet slowly filling your grey tank, or inaccurate tank gauges, which is very common.
(3.) This is where the air conditioner condensation tube is and water will normally drip there. More, or less, depending on the humidity.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Help! On the road and need assistance with hooking up water Jessie Plumbing - Systems & Fixtures 19 04-20-2015 08:21 AM
No water flow after hooking to city water Grevers911 Fresh Water Systems 8 06-23-2013 10:08 PM
trouble hooking up waste water outlet to sewer hose Molly1973 Waste Systems, Tanks & Totes 9 05-21-2012 06:38 AM
Trouble hooking gas line to water heater 63air Water Heaters, Filters & Pumps 8 09-06-2005 09:56 PM
Hooking Up Trailer Battery to Tow Vehicle flyfshr Batteries, Univolts, Converters & Inverters 11 02-27-2004 10:50 PM
