Old 03-20-2019, 06:20 PM   #1
1969 29' Ambassador
Prospect Bay , Nova Scotia
Honey Bee Hive between floor and under skin
We own a 1988 Excella 1000 located in ft Myers FL.
Last year (2018) just before we went north we discovered a full scale bee colony existed under the base skin just behind the hitch. Extermination is simple, however how to remove the honey and combs is the real problem!!
Any suggestions?.......
Airstream ns is offline   Reply With Quote
Old 03-20-2019, 06:32 PM   #2
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Drop the pan and cut it out with a putty knife then pressure wash.
Dept of “OverKill”
Old 03-20-2019, 07:10 PM   #3
2007 22' International CCD
Get it totally clean and sealed up. Any wax or honey remaining will attract passing bee swarms and they will promptly move in when they smell it. It can also attract ants and other bugs you don’t want.
Used to have beehives. Fascinating hobby and can be very rewarding. Middle kid got into it in Alabama.
Old 03-20-2019, 07:32 PM   #4
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Total hijack.....
Where in Alabama? I’m in Alabama! Always looking for a good source of local honey.
Dept of “OverKill”
Old 03-20-2019, 10:19 PM   #5
No longer in Alabama, sorry. There are several decent beekeepers in the Huntsville area where we formerly lived. Ask around.
Old 03-21-2019, 04:33 AM   #6
1969 29' Ambassador
When you say drop the pan I assume the aluminum skin. How is it fastened? Would be nice if it could be removed in one piece and reinstalled!
Was also thinking of cutting out section of floor (carpet needs to be replaced) and accessing hive from above????
Cheers.....
Old 03-21-2019, 04:45 AM   #7
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Not to interrupt the main topic (guess I did!)
We stayed at the Tumble In RV Park in Marfa Texas last year and a swarm of bees had made an entire AS their home. The AS was parked in the back with thousands of bees humming around it. The owner of the AS, and the park told the park manager he could have the AS if he could get rid of the bees.
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
***Support Airstream Forum***
turk123 is offline   Reply With Quote
Old 03-21-2019, 05:21 AM   #8
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Cheers.....
From the top would be a lot more work in my opinion. The belly pan is help in place with large headed poprivets and a few things mounted under the trailer, like stabilizers. You should be able to drop just the front part of the belly pan to access what you need.
Dept of “OverKill”
Old 03-21-2019, 05:37 AM   #9
Long Island , New York
Thumbs up
Exactly.
Welcome to the forum Airstream ns!
Peter
Old 03-21-2019, 09:56 AM   #10
Giovanni
Jbuccola's Avatar
2015 28' International
St Helena , California
I suggest getting a local bee keeper! These bees are precious and are in jeapordy around the country. We keep bees in our yard and they are so important to all of us! Good luck!
Jbuccola is offline   Reply With Quote
Old 03-21-2019, 01:15 PM   #11
The Panhandle , Idaho
Agreed. Please call a local beekeeper to extract the bees from the hive, NOT exterminate them. Honey bees are dying off around the world and the US has a severe shortage of bees. Beekeepers actually transport their hives across state lines to aid in pollination of important food crops. Without honey bees and other pollinators, plants don't grow.
Hoagie '59
Hoagette '57
Whitney and Tobin -- The Aussie Posse
Hoagie is offline   Reply With Quote
Old 03-21-2019, 01:24 PM   #12
StreamNTyme's Avatar
2007 25' Safari FB SE
Carolina Low Country , South Carolina
Images: 27
Yes, it is important to save the the hive, please do
put all efforts into saving them...
Good luck...
StreamNTyme
StreamNTyme is offline   Reply With Quote
Old 03-21-2019, 01:35 PM   #13
Steamguy's Avatar
2019 27' International
Washougal , Washington
Call your local Fire Department. They always have a list.
Steamguy
2019 International Serenity 27 FB
"Live, Laugh, Love"
Click here to go to my blog: I try to add wisdom, not noise.
Steamguy is offline   Reply With Quote
Old 03-21-2019, 05:52 PM   #14
1969 29' Ambassador
Thanks.....
Spray Foam Between Belly skin and floor rickysaetta Repairing/Replacing Floor &/or Frame 17 10-10-2017 05:10 PM
Hello from a new bee wanna bee iowaal Member Introductions 2 05-20-2014 08:35 PM
Need Advice- Bee Hive Removal hardcherry 1966 - 1969 Ambassador 4 09-27-2012 11:41 AM
Bee Hives under belly pans - is that the smell? godaddy64 General Repair Forum 0 09-29-2011 04:44 PM
Bee hive lights - '53 flying cloud kbw0221 Member Introductions 10 11-05-2007 09:36 PM
