Old 05-13-2013, 06:52 PM   #1
'67 Globe Trotter "Järv"
Slik's Avatar
1967 20' Globetrotter
Glacier NP , Montana
Holes through the awning rail?
Hello,
My dad and I are trying to fix a leak in a window and replace the floor in my '67 GT before my trip. We noticed three holes at the right end of the awning rail that seem to go clear through the aluminum. This of course is the side where I feed my awning through, so I'm not sure what's supposed to be there in its place. We'd appreciate advice on how/if we can fill them properly.
Slik is offline   Reply With Quote
Old 05-13-2013, 06:54 PM   #2
Slik's Avatar
Old 05-13-2013, 10:03 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Looks like you found another leak above your window... I am not familiar with the GT.. but, those holes appear to be places where the awning had "stop rivets" installed.. or some other device if the awning were not there..
To 'fix', well, you can squirt some sealant (NOT SILICONE) in there... and then slide in a round piece of aluminum to take up all the slack and divert water. Of course you would want your 'awning' to already be in place.
If, however you will be taking the awning in and out, then you need this space to be "serviceable". I suggest you seal with sealant and shape the area to allow the insert/install of the awning key strip (that is the initial part of the awning..)
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-13-2013, 10:24 PM   #4
Slik's Avatar
Whoops-a-daisy, he was caulking the window with silicone earlier. What would you recommend for the sealant? Would we use the same for the window? I do use my awning, so we'll use your tips to be careful. Thank you so much for your help!
Old 05-13-2013, 11:43 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Get the silicone off your aluminum.. it will corrode it.
Sikaflex is what I have used.. and it comes from Airstream company store in their 'reseal' kit. I would source it there for a quick turnaround.
Use it on windows, too.. get the gray/aluminum color..
There are other 'sealants' that you will find on the site and have good results.. just NO SILICONE.
Good luck!
Channing
WBCCI# 30676
Old 05-14-2013, 05:37 AM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Polyurethane sealant in the holes, insert a section of round AC cord in the channel, (light coat of dielectric grease), 'til dry.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Just because you don't know how, doesn't mean you can’t."
Amanamus
"Never tow faster than your Guardian Angel can Fly"
Sweet Streams....🌥
Old 05-14-2013, 11:51 AM   #7
Slik's Avatar
Could someone please share a photo of their awning rail (right) bracket? Before patching the holes I'm curious what was there before, particularly if it's not secured appropriately.
Thanks to all who have helped! The Air Forums is sure a great resource to help a lot of vintage trailers be better cared for.
Old 05-15-2013, 12:22 AM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Checknout ZipDee. They have pics that show the awning going in the slot. Mr. Cross gaave a better option to fix..then just keep an eye on it..you will be fine. Just make sure the awning is not fraying in that area.
Channing
WBCCI# 30676
Old 05-22-2013, 04:53 PM   #9
Slik's Avatar
An update (by request): I found the bracket and screws that fit into the right end of the awning rail, but since I need it open for my awning my dad filled the holes using your suggestions. Unfortunately it's still leaking here in rainy New Hampshire, but after spending one day at a Camping World in NY with a gas leak and my birthday getting new brakes I'm just glad I made it here. We'll try to seal the holes and window up again when I get home and out of the rain. Thanks for all the help!
Old 05-22-2013, 06:18 PM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Great! You will get it fixed.
Channing
WBCCI# 30676
