Old 06-27-2012, 08:33 AM   #1
1959 24' Tradewind
heathfield , east sussex
hitch and axle replacement
Hi
Can anyone recommend someone that can change the old usa hitch and axle to uk spec in south east england? Or carry out the brake controller refit? thanks
richardallen is offline   Reply With Quote
Old 06-30-2012, 09:26 PM   #2
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I'm not sure that the USA hitch can be swapped for a European hitch. USA hitch hookups are based on a minimum 10% of the trailer weight on the hitch - thus a 3000 lb trailer would have a minimum 300 lbs on the hitch ball; by contrast, the European hitch ball carries about 50 lbs. Consequently, your tow vehicle should be equipped with a 2-inch square Class IV hitch receiver and you could then use the corresponding equalizer type of hitch for that weight.
For braking, a typical Tekonsha controller would work well to activate the electric brakes on the trailer. As you no doubt know, the European trailers have a surge brake mechanism. Trying to retrofit that on the Tradewind would be costly, and may not be as effective as using the electric controller.
FWIW, I believe that the most economical and effective solution is to purchase an equalizer type of hitch and electric brake controller provided that there is no legal requirement to use the surge brake mechanism common to European & UK trailers.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
