05-25-2018, 06:31 PM
2017 25' Flying Cloud
Raleigh
, NC
Hit and run damage
While grocery shopping today, someone did a hit and run on our 25 FC. Luckily, someone saw the perpetrator and got a license plate. Any idea how much this might cost to fix? I don’t think the underpan got damaged, but is there anything I should be looking at to assess the damage?
05-25-2018, 06:35 PM
Overland Adventurer
2009 34' Panamerica
Telluride
A new bumper is about $350 and 4 new screws...
Sorry!
05-25-2018, 07:27 PM
2007 27' Safari FB SE
NW Oregon in a nice spot
, Oregon
Did you open the storage cover to see if there was damage to that, or did it stop with the aluminum? That will affect net cost.
05-26-2018, 07:38 AM
2018 30' Flying Cloud
South Hero
, Vermont
Hopefully it’s just a bumper.
The guy who hit me did more damage than a bumper[emoji20]
I haven’t seen an itemized bill, but this is about a $10K repair at Jackson Center (so far). Fortunately his insurance is covering it.
05-26-2018, 07:52 AM
Chelsea
, Maine
Mine was dented less severely than that (OP) from the dealership. They had to replace the bumper, lid, and galvanized pan. The decorative diamond plate floor was not damaged, but the galvanized pan underneath was. Be sure to get a good look at it.
2023 Entegra Odyssey 26M
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
05-26-2018, 12:08 PM
Link’s Travels
2002 25' Safari
1999 35' XL 350 w/slide
LINCOLN
, Nebraska
Bent bumper
I had a similar thing happen to me. I took off the bumper (very easy, only four screws as I remember), took two short 4” x 4” boards; placed the bent bumper between the boards and gently pressed my entire weight (180 lb) on the bumper, where the bend was, and it straightened out. If yours does not have a crease in it you should be able to do the same. Even with a crease it might still work.
I then touched it up with some auto silver spray paint. Good as new now!
05-26-2018, 12:54 PM
2006 19' Safari SE
Tucson
Sorry for your hit and run ... Lucky that you had a bumper to take the damage...that's your silver lining here. It did its job.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
05-27-2018, 08:35 PM
Raleigh
, NC
Thanks for all the responses. The galvanized pan seems ok, but diamond plate floor is damaged. I am going to await the police and insurance results and depending on the outcome, may try repairing it myself.
05-27-2018, 08:36 PM
Raleigh
, NC
Counting my blessings mine was not nearly as bad as yours.
Attachment 312027
05-27-2018, 09:50 PM
Tampa
I think you just named my Airstream!
Silver Lining.
That made me wonder if anyone keeps a record of trailer names?
And is it bad form to use one already in use?
06-04-2018, 04:53 PM
2015 27' FB International
Seminole
From my personal experience and what I see in the photo, the top cover has been pushed into the trailer some breaking the seal. It goes in about 6 inches and is covered in foil. The interior plywood rests directly on top of it. If it is not sealed correctly, water sitting on the cover leaks into the trailer and wicks up through the plywood, rotting it out. I had much less damage than you and was lucky that I felt a little softness in the floor by accident. I was able to repair the floor and seal the seam before it got to where inside skins would have had to be pulled to get at the carriage bolts.
To be sure after I was done, I had the trailer leak tested. They still found and sealed a couple of little spots that my sealing missed. So don't just look the repair from the immediate cosmetic point of view. There may be more things that can show up later.
06-06-2018, 07:54 AM
Raleigh
, NC
Thanks for all the ideas!
Joe
06-06-2018, 08:03 AM
2018 27' Tommy Bahama
Marana
Silver Lining.
You can register your name with Airstream if you like and see what others have named theirs.
https://www.airstream.com/community/name-registry/
2018 27FBQ Tommy Bahama - "Indecision" w/Blue Ox SwayPro, Centramatics, Dual EasyStarts, Airstream Connected, Airtug Trailer Tug HD
2012 F250 6.7 Powerstroke King Ranch - "Earl", Centramatics, Viair On Board Air
06-06-2018, 08:08 AM
Draper
, Utah
This one was done by the storage facility where we USED TO park our trailer. They basically denied doing it and said there was no proof they did it.
It was underneath the drivers side rear window.
06-30-2018, 12:11 AM
2019 27' Globetrotter
Salem
, Oregon
Someone left me with a scratch on the side about a foot long and the scratch is not very deep but you can feel where the material is raised. Is there any decorative aluminum that one can purchase that could be placed over the damage.
Dave
