02-02-2004, 08:45 AM
1967 26' Overlander
Huntsville
, Alabama
Hints-n-Tips
I'm all the time looking for something small, and disposable on which to mix two-part glues. The perfect solution dawned on me the other day while I was rebuilding one of my backup lights:
If I determine it will work with a soda can, I think I'll send it to "Heloise"
02-02-2004, 09:14 AM
Hints
Great idea!
Would this work with fiberglas resin?
It think it would make large projects a lot of fun.
02-02-2004, 09:33 AM
1967 26' Overlander
Huntsville
, Alabama
No, you'd need a keg for that much resin...When do we start?
02-02-2004, 10:34 AM
Hillsboro
Pre-project Prep
I'll help with getting the keg ready  !
02-02-2004, 02:34 PM
Eastern
[If I determine it will work with a soda can, I think I'll send it to "Heloise"]
Good idea - but you would have to actually find a soda can first! The one in your post was NOT a soda can (just in case you were confused)
77 Argosy Minuet, 6 metre | 1964 Overlander | '08 Touareg V6
AIR # 3181 |
Bullies thrive where leadership fails
02-02-2004, 03:16 PM
1959 24' Tradewind
Phoenix
Oh yeah...I've been building flyrods off and on for a couple of years and I use these to mix the small amounts of epoxy in. It's best to empty cold contents before using as a mixing tray.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
02-02-2004, 06:55 PM
St. Cloud
I dunno FF -- from my experience too large a pot mix has problems from the exothermic heat of reaction. Leaving the liquid in would be a good heat sink.... (pay no attention to the green skin, bumps and antennae).
I've still got quite a stockpile of small plastic yogurt containers from when my kids were still in high school. I keep seeing aluminum can themes in working on our aluminum trailers... It figures!
Make sure not to use waxed anything with epoxy -- paper cups, etc. It will give you unpredictable problems with bonding.
02-02-2004, 07:08 PM
I mix 2 part epoxy on a small PIECE OF PAPER like a post-it-note.
Dick
02-02-2004, 09:43 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
i think a miller can would work better!
john
you call them ferrets, i call them weasels.
02-03-2004, 12:03 AM
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County
, Ohio
hints
An Old IBM formatted CD makes a great mixing surface too.
02-03-2004, 05:42 AM
2005 19' Safari
West Palm Beach
AOL is now sending out their free Intro software in a flat tin can. Before sending it to file 13, save the can for mixing ...
By the way, does any one brand work better than another ... is Milwaukee's Best any better than Mabel's Black Label?
Stephen & Miriam
2005 Bambi Safari 19 LS with Sofa
2006 Harley-Davidson Road King Custom
2005 Dodge Ram 3500 CTD QuadCab SRW Long Bed
Sir Wooferman Wellington, Cock-a-poo Watch Pup
05-29-2005, 07:04 AM
1967 26' Overlander
Huntsville
, Alabama
Near tragedy almost occurred last week when I dropped a bottle of Walbernize from the top shelf and split the bottle's bottom. Thinking it was worth a shot, I hot-glued the 3/4 inch split. Success! No leaks.
Tom
05-29-2005, 07:55 AM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
FF
So that is why these empties are still "sticking" around
Aaron
WBCCI #XXXX AIR #2495
| Thread Tools |
| Display Modes |
