02-07-2016, 05:06 PM
vagabons
city
, province
Hickory Cupboards Split - Dining Table Warped !
Hi,
New to this forum and relatively new to owning our 27 FB Classic. We bought it last year in July 2015 and it is a 2012 with all the lovely hickory wood everywhere. The unit is immaculate, saw very little use since new.
We have checked it regularly all winter, keep one of those little round heater/air circulators on in it all winter. Just went out now and noticed the dining table warped a lot on the rear corner and then noticed quite a few cupboards had split really badly! So very disappointing. We will call Airstream on Monday but wondered if anyone had any problems like this with doors? Surely after 3 years all the wood should have settled and been seasoned well enough not to do this. It always lived in NW - Oregon or Washington first and then British Columbia the last couple of years.
So PO'd to see all that lovely wood like that. Advice to deal with Airstream also appreciated. Thanks. We were all excited as we are fairly newly retired and heading across Canada this year for a few months!
02-07-2016, 06:03 PM
2006 25' Safari
Signal Mountain
, Tennessee
Originally Posted by vagabons
Hi,
I have no idea of your humidity levels, but problems of this sort can be caused by extremely low humidity. Wood is usually dried to about 12-16% moisture content. When humidity gets below that level it will dry the wood even more, and it will start pulling at joints. Also it can open up "seasoning" cracks. Wood is very much an organic material, and is not static. Honduras mahogany is one of the more stable woods. That is why it is used in furniture and in making patterns for castings.
Try to put a humidity level indicator in there. If it is too low run a humidifier until the wood starts expanding back.
Don
'06 Safari 25 LS
'18 GMC 2500HD Duramax/Allison
TN,”Greenest State in the Land of the Free”.Davy Crocket
" America is not a place;it's a road." Mark Twain
Oswego
Hmmm, hickory is a very straight grained wood and splits very easily...with an ax or through drying and extreme temperature /humidity changes. I had one small split in the door below the sink when I bought my 07 in 2010. I have noted no more to date. I have not investigated, but there are effective repair methods using filler and other specific processes. I would have thought after 3 years, yours would have seasoned completely. Don't even know what to say about your table. Mine has been fine.
-Rich-
02-07-2016, 06:29 PM
2006 25' Safari
Signal Mountain
, Tennessee
Just did a quick search, and this turned up. Hope it helps.
http://www.canyoncreek.com/wp-conten...ffectsWood.pdf
Don
'06 Safari 25 LS
02-07-2016, 06:49 PM
1993 34' Excella
York
, South Carolina
It is probably not so much the wood at fault, but the environment it is living in.
The doors are made using frame and panel construction so the panel, inside the door frame, can shrink and swell with seasonal changes in humidity and hopefully not distort or wreck the entire door. Sometimes they can still be a problem.
If the panels in the doors have cracks, likely a sign of shrinkage in the panel from low humidity.
If the corners of the door frames are opened up (joints pushed open), a sign of swelling in the panel...too much humidity.
Airstream would use kiln dried lumber in their cabinetry, which is typically dried to 6-8% moisture content.
The cracks might correct themselves somewhat once humidity is introduced to the interior. There will still be a crack, but less noticeable.
As for the table, not sure how/why only 1 corner would curl up.
There is really no fix for cracked doors except replacement or at least an appropriate filler applied and then refinish them. Pretty involved process.
Then, it could still happen again.
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 Past President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?..... Uncle John's Band
02-07-2016, 06:55 PM
1993 34' Excella
York
, South Carolina
I might add that Hickory is a course, open grained wood that is more susceptible to moisture exchange than other closed grain wood like the Cherry used in the new Classics.
John
02-08-2016, 11:29 AM
Likes Shiny Tings
1958 26' Overlander
Portland
, Oregon
We've noticed unusually high humidity this winter in the Portland area. Perhaps that is a contributing factor for the rainy parts of the PacNW.
Even our motor vehicles have been all wet on the windows inside on many days.
When Fall comes, I always set out a couple of containers of DampRid moisture absorber in my trailer to ward off mildew or warping.
02-08-2016, 12:41 PM
2008 25' Classic
Full Time
My Table is Warpped Too
I never noticed this until I moved from Texas to Missouri.
Just for grins, I put the table down on the dinette. put towels on the table and placed my Equalizer bars on the table to see if a little weight over the winter storage might straighten it out.
If it doesn't I'll take the table to a cabinet maker and see if they can do something to it. It might mean having to refinish the top. I wonder if the table could be supported by routing out some channels and epoxying in metal flat rods on the undesides.
If they say the warp can occur again then I may have to live with it.
You may have to take the spilt door to a cabinet/woodworkers shop.
I wonder if treating the cabinets with Liquid Gold would help prevent drying out?
Kelvin
02-08-2016, 12:55 PM
2012 23' FB International
Woodstock
, Ontario
Your table appears to be properly laminated with most plank grains reversed to the one adjacent.
If the table is warping from moisture and internal stresses no amount of restraint will hold it. If you do need to have it flattened, then be sure to finish all faces of the table to keep moisture from acting on only one face. A urethane finish on the top and no finish on the bottom will allow the bottom face to swell and curve the table up at the edges.
JCW
02-08-2016, 12:57 PM
2012 27' Flying Cloud
W
, New England
If lack of humidity increases the odds of splitting, I wonder if the constant heater/air circulation on all winter contributed to the problem?
02-08-2016, 01:33 PM
2008 25' Classic
Full Time
JCW
It doesn't appear there is much on the underside regards to sealant. Maybe when the weather gets warmer and more humid the weight on the table will gradually straighten it better and I can try to seal the undersides myself.
Kelvin
02-08-2016, 07:06 PM
2010 27' FB Classic
Clearwater
The table in my 2010 started warping in less than a year and eventually split. By the way I live in FL so low humidity is not a problem. I had the table replaced under warranty. Before installing the new one I glued and screwed 3 angle iron bars across the table width. No problem over 5 years and many thousands of miles.
02-09-2016, 05:24 AM
1967 30' Sovereign
Nauvoo
, Alabama
This is not an AS problem alone. I have had to replace tables in two other makes, both had a different table manufacture. As a wood carver I tried sealing both sides of the solid wood I used in one unit and using nothing but natural Swedish wax on the top of the other. Both tables have not given us any trouble and visitors seem to like the look and feel of the one with only the wax on top ( Many coats of high quality wax can take one my carvings from ordinary to extra ordinary and it amazes my how it brings out details so much more, so be aware of flaws in your wood, you will see them and to me that is a good thing.
To all who served - give them thanks - give them respect - may God give all many blessings (Ray Bozeman)
02-09-2016, 05:32 AM
1993 34' Excella
York
, South Carolina
Wood continues to shrink and swell with seasonal changes, even after it is kiln dried. It cannot be stopped but sometimes can be controlled to a certain extent by the way the product is constructed. The furniture industry avoids this by using man made sheet goods. No shrinking/swelling to contend with.
Cabinet doors, both residential and in the RV industry, use ''frame and panel'' construction to help avoid problems. The panel ''floats'' inside a groove around the perimeter of the frame, allowing it to shrink and swell. Careful measurements must be made during construction to allow room for this movement to take place.
Large table tops present even more problems, as the thicker and wider the board (top), the more it moves. It must be finished equally on both sides and particularly the ends to seal it up. If not done, warping usually occurs.
There are always exceptions, but it is risky to use battens underneath to hold the top flat unless you slot the screw holes to allow for the seasonal movement.
All this can go right out the window when you consider a trailer made in Ohio, with humidity ,then ships to Arizona, with no humidity. Care must taken at the factory to consider the things I mentioned above, and we all know how things at the factory can sometimes be.
John...furniture maker 40 years.
John
02-10-2016, 10:06 AM
vagabons
city
, province
Hi all,
Thanks for all your input especially John, the sandlapper! My husband said the same thing about the cabinet doors, there seems to be no allowance there for movement between the panel and the frame, too bad. We removed the table from the trailer.....boy, not an easy task.....heavy sucker! The rear left side had warped up which makes sense because it is not sealed on the bottom.
There is a wooden batten thing on that edge but the end screw had actually broken off when the table edge started to move and so that corner just moved upwards. We brought it in, clamped it and rescrewed it and it is laying flat upside down in our living room with weight on it and we will see, it does already look a lot better.
Where we are on Vancouver Island, lack of humidity is NOT the problem !
This was a bad winter for rain and humidity and we now think that little unit we used was not enough. It is a Stor-Dry low wattage warm air circulator by Caframo, designed for marine and RV use. We just now have put one of those oil filled heaters out there on really low, but obviously it is starting to get warmer now so we are too late in the season! My husband will take a door off and see what happens inside.
John said this: ""If the corners of the door frames are opened up (joints pushed open), a sign of swelling in the panel...too much humidity.""
That looks exactly like what happened. Don't know if we can ever get them 100% again and if we spend a bunch of money to do it, it might just happen again during the next winter. John, any advice for us to try before we go the cabinet maker route? We are new to BC too, it is amazing how it really is the "West Coast".
Basically we were just so shocked because it is not new, we figured that type of thing would have happened already.....and it was living in the NW since delivery.
Just made us sad and disappointed.
02-10-2016, 10:45 AM
2008 25' Classic
Full Time
As lovely as the Classic table looks I'm not finding the finish on it to be practical. Somehow one of us put something on the table that ate away the finish leaving a quarter sized ring. I'll probably have to get the whole table sprayed.
As mentioned above its heavy. Letting the table down isn't bad put swinging it up can only be handled solo by myself, the wife needs help, so we don't take it down often.
But, its what I've got and I've learned to live with it.
Kelvin
02-10-2016, 02:31 PM
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach
, British Columbia
Vagabons , we are just down the road from you in Qualicum and will attest to the " no lack of humidity"
Last year on our trip south we had a lot of moisture issues ( 3dogs, 1cat and 2 humans) so after a lot of research we picked up a small EVA DRY 1100 which really keeps the moisture down for winter storage here. Our selling dealership Midtown RV in Penticton even uses the 2200 model in the Newmar motorhomes they sell.
So far this year, no damp smell at all and no moisture on my windows.
Hopefully after fixing, your tabletop will become acclimatized and not warp again
George
02-10-2016, 02:35 PM
Wise Elder
2010 30' Classic
South of the river
Hello vagabons
I too have the hickory cabinetry in my rig.
We have had problems with warpage only on the sliding door to the bedroom. We did however run into problems with the finish cracking and crazing on one of the folding tables (not the dinette one; there are two smaller ones in the 30', not sure if yours will have them). It was replaced under warranty shortly after I bought the trailer and is starting to craze again now.
I have had to replace some of the plastic friction catches on the cabinet doors. Whether this is because of alignment problems due to expansion and contraction of the wood, or the fact that the plastic friction catches are junk, I am not sure. I am using brass replacements and they work better.
I agree that the table is unnecessarily and inappropriately heavy. Who knows why they do what they do.
I don't have much specific advice on repairs, but I hope you can get out and enjoy your trailer and see how things go and whether some of the changes are temporary.
We do not try to heat our trailer in the winter.
02-10-2016, 06:40 PM
1993 34' Excella
York
, South Carolina
vagabons,
once the doors are pushed apart at the joints, not much can be done with them. They are toast. Often the swelling splits and cracks the wood in the joints anyway. The panels themselves could possibly be reused, new frames made.
It sounds like replacement is necessary. If/when you talk to a cabinetmaker, just explain what has happened and quiz him on his construction techniques. The grooves in the frame must be deeper than the panel is wide to allow for the expansion.
Many factors come in to play with any wooden product.....moisture content of the wood and how carefully it was dried, hidden stress cracks, where the piece eventually ''lives'' in relation to where it was produced, the type of finish used, type of construction, quality of fit, and most of all...the human factor.
Sometimes things go wrong despite the best intentions.
Equal finish on both sides of the doors or table tops is perhaps the most important step. It stabilizes the piece.
Everyone out there in Airstream land, take a look underneath your table. If there is no finish, or very little compared to the top, pull it out and brush on a coat or two of polyurethane. Doesn't need to be pretty, just get it on there.
As for water proofness, there are products out there that provide excellent protection. The polyurethanes and varnishes are very good. I would not recommend applying a fresh coat of either on an existing finish, adhesion and other problems can occur.
Laminates on particle board substrates are the most stable and trouble free.
Wood is good. It must be assembled correctly or the types of problems discussed here will show up. And sometimes they just show up anyway.
Not gonna point any fingers, but a tour of the factory will tell you first hand just what kind of pressure the workers are under to get the product out the door.
John
02-10-2016, 08:01 PM
1994 30' Excella
Mississauga
, Ontario
Kelvin,
If the bottom has no finish then as the humidity goes down(usually winter) that surface will dry out fastest and shrink which would account for the warp. There is a chance that when the humidity increases it will swell and straighten out. That would be the time to seal the bottom surface to prevent it from happening again.
Door manufacturers always say seal all surfaces in an identical fashion or no warranty against warpage.
Al
Al and Jean
TAC ON-3
