Old 11-21-2018, 02:07 PM   #1
drlora's Avatar
Jackson , Georgia
Help with rear compartment door latch
Please help me! I have a 2005 28’ CCD International and one of the latches on the rear compartment door is having issues. I guess the screw isn’t holding like it did and it won’t stay together. I contacted the Airstream factory in Ohio and spoke with the service department about getting a replacement latch and supposedly it has been discontinued and is being replace with a much smaller one that would leave a big gap. (Am I making sense?) Here are some pictures that may help........ As it is I am only able to lock one side and am worried that I might start having problems with that one soon!
[ATTACH]328285[/ATTACHClick image for larger version
drlora is offline   Reply With Quote
Old 11-21-2018, 03:18 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard!! 👍
Is the assembly turning on the door? Or is the phillips head screw just loosening so the latch arm swings free/
What I had to do to our locks...
Remove the assembly Clean & make sure the lock ring on the back side is tight when you re-install. Use a star washer and Loctite on the threads.
I did have one lock on our battery box that required a bit of 3m 5200 under the front side to keep it from turning.
Good luck 👍
“Not enjoying the Network News Broadcast?…ask your Doctor." 🤪
RLC
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 11-23-2018, 05:05 AM   #3
drlora's Avatar
Jackson , Georgia
Thank you Bob! The screw becomes loose and the latch arm swings free. I will try the star washer and locktite. Thanks again!
Lora
Rear Compartment Latch for 70's AS bombard16 Exterior Storage Compartments & Access Doors 0 06-29-2017 08:21 PM
Compartment door hinge/safety latch/wire rideair Exterior Storage Compartments & Access Doors 6 05-11-2010 02:24 PM
Latch/Catch for compartment door slk Exterior Storage Compartments & Access Doors 1 05-02-2010 09:09 AM
Installing a Door Knob (Latch or Not to Latch) rslaymaker Doors & Locks 2 11-17-2009 10:52 AM
rear door storage compartment lock and latch maxandgeorgia Bumpers & Bumper Storage 4 08-06-2006 10:00 AM
