Old 04-10-2013, 09:02 PM   #15
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
All things considered, you may want to ponder driving the 730 miles from Salida CO to Tucson AZ and have the guy there do the whole job. The warranty is the same as going with a new unit, but I believe that the cost will be much less. As I said, they replaced the fridge in my friend's 5th wheel and he was most satisfied with the job. Because they rebuild all the cooling units, they meticulously inspect the welds (better QC than Dometic's factory). As well, they made my friend stay for a few hours to ensure that the unit worked properly.
I recall them setting up an appointment for the work to commence at 8:00am.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 04-12-2013, 10:54 AM   #16
MtnCamper07's Avatar
1993 30' Excella
Salida , Colorado
Thanks for all the responses... will make some calls & do some research. More to follow!
NB
MtnCamper07 is offline   Reply With Quote
Old 04-12-2013, 11:49 AM   #17
1986 31' Sovereign
Miami , Florida
I think William H. And I were both thinking that if you fired it up on AC and/or propane, and the heating element ( or the flame) came up to temperature, then that would indicate that your control board is still okay.
It won't hurt anything, the reefer just won't cool since the coil is bad.
Good control board plus box in good shape would suggest that coil replacement would be logical. If the control board is bad and the box rusted, dented, ugly then maybe new is in order.
Mike
Old 03-30-2014, 11:37 AM   #18
1993 30' Excella
Salida , Colorado
Well, a year later and I am still facing the same issue... I did fire up the fridge and saw that the circuit board worked. I will make some calls and see if it is possible to repair the existing coil (still on fridge). Failing that, I will have no choice but to replace the entire unit. To be continued....
NB
